Problem with Stock Stereo
Old Oct 19, 2008
jayd's Avatar
jayd is an unknown quantity at this point
After starting my 2005 civic lx, the stereo played for about four seconds then died. Two days later, I turned it on and it played four eight seconds and died. I can still turn the volume up and adjust controls, but I have no sound coming out of it at all. Does anyone know what could cause this? Thanks in advance.
Old Oct 19, 2008
manahoonie's Avatar
Re: Problem with Stock Stereo
... antenna problem?
Old Oct 19, 2008
does tape player work? deck powers down completely or just doesnt play sound?
Old Oct 20, 2008
jayd's Avatar
The deck still has power. All the controls work: Bass, Treble, Fade, Bal, Volume. Can still change radio stations. Just doesn't play sound
Old Oct 20, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Factory or aftermarket radio?
Old Oct 20, 2008
manahoonie's Avatar
...does...
...the...
...tape...
...or...
...cd...
...player...
...still...
...work...
Old Oct 20, 2008
jayd's Avatar
It is a factory stereo. No tape player, has single cd. Cd player does not work. No sound from CD, AM or FM. I get nothing.
Old Oct 21, 2008
CraigW's Avatar
Could be the output IC died (possible bad solder connections ??)
Any strange noises before the sound went out ?? Noise or sound cutting in and out ??
Most likely aftermarket replacement deck would be cheapest option.
Old Oct 21, 2008
mickeycivic04's Avatar
mickeycivic04 is a jewel in the roughmickeycivic04 is a jewel in the roughmickeycivic04 is a jewel in the roughmickeycivic04 is a jewel in the rough
time for a new cd deck!
Old Oct 21, 2008
ciVictoria's Avatar
Time to upgrade your music. Alpine deck with some new interiors ;]
Old Oct 21, 2008
Although I'm sure to be shouted down, possible bad/blown/blowing speaker.
Old Oct 21, 2008
tbaleno's Avatar
tbaleno is an unknown quantity at this point
He would still hear sound out of the others. Sounds like the radio. Could be a solder joint that needs re-soldering.
Old Oct 22, 2008
Only if the bad speaker were blown open, ie resistance is infinite.
If the speaker is blown short (resistance is 0) it's very possible to shut the entire chip amp down as a safety measure.
I forgot to add a grounded speaker wire, I just got done with a call where a grounded spkr was shutting down the factory radio.
Old Oct 22, 2008
tbaleno's Avatar
Never thought about it shorting. Good point.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
crowtoo
May 11, 2015 06:50 PM
supercivic01
South
Nov 30, 2001 11:27 AM
SilverStreak
Nov 21, 2001 10:38 AM
