1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
engine swap 94 ex
Old Sep 30, 2008
snaredevil's Avatar
snaredevil is an unknown quantity at this point
engine swap 94 ex
I am the proud owner of a 1994 ex 2dr coupe v-tech. she has been a great car for me but at 300,000 miles the engine finally has taken a big dump on me. and i figured since i'm going to have to replace the motor anyway why not throw in something with a little more power. i've narrowed it down to either a b16,b18,or a k20. which would give me the most bang for my buck and which would be the easiest swap? also any other suggestions as far as engine swapping would be much appreciated.
Old Oct 2, 2008
94CivicRicer's Avatar
94CivicRicer is an unknown quantity at this point
Thumbs up Re: engine swap 94 ex
One thing That I love about Honda's is that you can fit a lot of different types of engines in them But From what I think is that the b18 is one of the funnest engine to mod and just to add they are vary fast. I was planning on putting a b18 in my 94 coupe but didn't have the money. My friend just put a b18 in his 930 hatch and it barks all the way through fourth gear. For the Money I would go for the B18. Its all about what you want though, Hi End Or Low End......
Old Jan 24, 2011
dragonsdad67's Avatar
dragonsdad67 is an unknown quantity at this point
I also have a 94 civic ex will a B16A 1St Gen DOHC VTEC Engine fit in place of the original b15a SOHC VTEC also do I need to swap the ecm?
Old Jan 24, 2011
94civicd16z6's Avatar
The Boss ;D
94civicd16z6 is an unknown quantity at this point
same thing on my mind, what engine to swap into my 94 civic ex coupe. although my engine is under 150k and running smooth, (knock on wood), when it blows what should i swap? or rebuild or replace d16 and turbo? all motor? or i am thinking b16 or b18? most common swaps for these civics as far as i have heard and read...
d16z6- 125 hp, 106 ft-lb, 9.2:1 compression, 7200 RPM redline
b16a 1st gen- 158 hp, 112 ft-lb, 10.2:1 compression, 8100 RPM redline
b16a 2nd gen-168 hp, 116 ft-lb, 10.4:1 compression, 8400 RPM redline
b18c1- 170 hp, 128 ft-lb, 10.0:1 compression, 8100 RPM redline
b18c5- 187 hp, 131 ft-lb, 10.6:1 compression, 8200 RPM redline
but all at a cost. especially the c5! im thinkin a b18c1 or b16a 2nd gen but still in the air... and about the b15 & b16 swap, sorry i dunno, but bumped
Old Jan 24, 2011
MindBomber's Avatar
Live for the Twisties
B16 and B18 are the most common swaps done, because the are affordable and have lots of good bolts ons available. The b18c5 is extremely expensive though, around $5k last time I looked, so I wouldn't suggest going with that motor unless your very serious about building up your car.
If you want serious power and you have a decent budget go for an h22.
Old Jan 25, 2011
The Boss ;D
thanks mindbomber, but h series? i have never heard of anyone putting an h series in a 5th gen. specs? members cars? anyways, while the topic is at hand, and the top of the forum... the b18c5 is wicked, but 5k for the swap is too much for me, and i would just want to buy another car! but, the b18c1 and b16a2 you can find for about 3k complete swap. or rebuild kit for d16z6 for cheap as like $500, but probably spend a little more and get a decent one so you can soup up that sohc to the max and show those dual cammers how we roll! but no, seriously, i think i'm getting a b16a 2nd gen swap when my engine blows. 3k, b16 bolts up nicely in my car i hear, going to love the 8400 redline (vtec sounds amazing, + the higher the rpm the more pull), and as mindbomber said, lots of bolt ons for these engines, sounds like a great engine. also i hear the smaller the engine (b18 vs b16) the less distance the pistons travel so less wear, especially when at high rpms. let us know what swap you do!
Old Jan 25, 2011
MindBomber's Avatar
I don't know if anyone here has an h series in a 5th gen civic, but it's been done, it's just not as straight forward as B series.
In 1-6th gen Civics really anything is possible if you have the skills, someone in my local club even has a c30a in an eg.
Old Jan 25, 2011
The Boss ;D
so what do ya think.. b18c1? or b16a? i heard you can use your d16 motor mounts for the b16, so that would save a couple bucks, although i would replace them to be safe. i think the b16 would be good, turbo it, and all the bolt ons of course. i expect to get 250+ hp to the wheels in my civic after i swap! i'm planning on the b16a 2nd gen, decent price, great stock specs! swap will cost i guess 3k and i plan to spend the same on the turbo.. + will have to buy the turbo manifold, new exhaust, etc. anyways, any reason you would pick a b18c1 over the b16a? or a different swap?
Old Jan 25, 2011
MindBomber's Avatar
I'm partial to the b18c1, thats a pretty bullet proof motor and a little easier to build up than a b16a.
Old Feb 3, 2011
keeper23's Avatar
keeper23 is an unknown quantity at this point
i also have a 94 ex coupe, which sadly i just got in a wreck with but should be able to fix. for now im just going to fix it to where she is running good but i recently bought a d16z6 motor, i got it on the cheap because it was only the block for the most part, i want to rebuild it and make it a turbo motor, where should i start?
Old Feb 7, 2011
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
http://www.facebook.com/track2street...91003&aid=1848
i think the link works i hope. Its my buddies its friggin nasty. He said he had an account here.
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
