8th Gen 2006 - 2011.
Aftermarket XM Radio Installation
Old Sep 19, 2008
krazymatt's Avatar
krazymatt is an unknown quantity at this point
I have a Terk Commander XM radio receiver I took off of another vehicle, and was wondering how difficult it is to get into the dash/console housing of our Civics? The Terk Commander is a tiny radio face with a main control box you have to mount somewhere hidden. Any input is greatly appreciated. Also what method would be the best to install the XM antenna and run the wiring? Thanks.
Old Sep 19, 2008
Re: Aftermarket XM Radio Installation
its pretty easy to take off, theres diy somewhere. basically a few screws and it all pulls out. you can mount the antenna inside the car on the rear deck lid and it will still get good reception if you dont want messy things on the outside of the car.
Old Sep 24, 2008
krazymatt's Avatar
Okay so I was able to pop off the upper front part of the console and there's likely enough room in there for the brain of my XM radio and there's a perfect spot for the face in the little coin tray just behind the shifter but where would I tap in for power and ignition power??-This is a hard-wire in unit; I hate to have to tear into my car too much. Thanks...
Old Sep 24, 2008
well you should run a new power line from the battery, imo.
Old Sep 26, 2008
krazymatt's Avatar
Question Re: Aftermarket XM Radio Installation
That shouldn't be too hard, but my unit has a wire for switched ignition power as well as a battery lead. Where would be the best place to tap into ignition switched power for that wire? I'm really trying to get away from removing the stock radio. That seems like no fun. I can survive with no ignition swithed power I guess, just run the battery wire two both those wires? Thanks
Old Sep 27, 2008
im pretty sure its just a remote turn on type of a deal for ignition power. you can prolly tap the main ignition wire under the steering wheel covers, maybe even the 12v socket power. since the unit is powered by the battery cable, i dont think the ignition power has to be a big wire.
mapdog
Jun 22, 2015 05:36 AM
Youshoe
May 22, 2015 09:36 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
mugenca
Apr 16, 2015 12:15 AM
