1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
end of the line for daughters 92?
Old Sep 3, 2008
oakfall's Avatar
oakfall is an unknown quantity at this point
My daughters 92 civic started running rough so I changed spark plugs. All the plugs looked great untill I pulled the wire off of the last plug and it came up covered in oil. The whole plug wire was submerged in oil.
What would cause this?
Thanks for any help,
oak
Old Sep 3, 2008
TRIZ's Avatar
Re: end of the line for daughters 92?
Either the spark plug isnt threaded properly and your have some serious issues going on in the cylinder that are causing oil to enter, or the more likely option would be a sloppy oil change where oil spilled over the valve cover and down the spark plug tube. If the threads look good and there are no cracks in the plugs tube, then it was probably someone doing a crappy oil change.
Old Sep 3, 2008
oakfall's Avatar
Thanks Triz, I must have a problem in the clyinder cause I changed the plug and it was re-flooded with oil again.No water in oil just straight 5w30.
Oh well, 180k so I can't complain.
Thanks,
Oak
Old Sep 3, 2008
lordhelmet's Avatar
Call me crazy but would there be an o-ring gone bad?
Old Sep 3, 2008
oakfall's Avatar
But then again I'm not burning oil so maybe O- ring is it.
Not sure where to begin the search?
Thanks for the help
Old Sep 4, 2008
lordhelmet's Avatar
Check out majestic honda diagram of the head. Get someone else to confirm it but I bet that could be it (if there is an o-ring in the first place)
Old Sep 8, 2008
i just had this problem with moms 92 accord. two of the plugs and the wire boots were dripping in oil. i ended up changing the valve cover gasket and spark plug seals and then putting new plugs in. so far the car starts much faster and easier, and after 3 days the wire boots and plugs are bone dry. hope it helps. valve cover gaskets and seals were $20 at auto store and took maybe 30 mins working slowly to fix.
ZILLA
Jul 13, 2015 04:52 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
robbie374
Jul 7, 2015 02:56 AM
danace99
23
Jun 28, 2015 08:49 AM
