Will not start , Turns over fires rom gauge read 9k
Old Sep 1, 2008
blinger's Avatar
blinger is an unknown quantity at this point
Ok i have check the fuel system thruout and all sensors. Everything check fine to manual . Also check ignition and its is also firing just fine. Have volted and ohm evrything possible under hood and all within spec . The car turns over sometime will fire for a second roms show 9000 but it dont sound like 9k . And dies .Strong fuel oder. Timing seems fine also checked tdc sensor the cyk sensors all checked fine. All fuses are fine also. Compression yes it fine and spec within range .
Any other ideas ? No cel codes
Old Sep 1, 2008
Re: Will not start , Turns over fires rom gauge read 9k
did you check fuel pressure?
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
usajags84
May 10, 2015 08:11 AM
tylerginevan
Apr 27, 2015 12:29 PM
Blaster30
Apr 22, 2015 12:21 PM
