Timing belt broke. Is my engine done?
Old Aug 20, 2008
grey2k11's Avatar
grey2k11 is an unknown quantity at this point
I was driving my car a day or two ago on the highway. Goin a good 70. My car stopped accelerating and slowed down to a stop and turned off. When i try to start the car it won't start. Just keeps making a weird belt noise which seems to sound like the timing belt.
I brought it to the mechanic at honda and he said my motor might be done.
Honda just had my car two weeks ago for bent valves and they replaced the timing belt and water pump. Could they have put a faulty timing belt to cause this?
Old Aug 20, 2008
Rufus's Avatar
Re: Timing belt broke. Is my engine done?
Or a bad tensioner, couldn't tell you until the car is apart.
Old Aug 20, 2008
couldnt say without looking. maybe can be fixed but someone looks like messed up on the repairs. this happened on a 92 accord here and the belt slipped 22 degrees and engine was dead. but then they changed the belt and amazingly the engine was fine.
Old Aug 20, 2008
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
Going that fast, it is probably done. How many miles are on your car?
Old Aug 20, 2008
well find out what exactly happened. if the belt broke, honda owes you a new motor.
Old Aug 20, 2008
DDragon7's Avatar
Well if Honda was just messing with it the last time you took it in, have them fix it.
Old Aug 21, 2008
speedfoos's Avatar
My guess is they ****ed up the tensioner when they put the timing belt and whatnot back on. The tensioner probably backed out, threw your motor of time, and you now have 12 freshly bent valves - all 16 if the engine was in VTEC - from when the tensioner went out. It's also possible the pistons were damaged when they hit valves, possibly the rod bearings too if they hit hard enough. My guess would be just valves though because you probably just cruising at 75.
Bottom line is that if Honda just did your T-belt, the mechanic put it back together incorrectly and caused this problem. Do not accept any other answer from the guys at Honda. They caused this.
CarStuff
Dec 6, 2020 12:52 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
CivicVoz
Apr 16, 2015 08:07 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
