ARP torque
Old Aug 13, 2008
civcspool's Avatar
civcspool will become famous soon enoughcivcspool will become famous soon enough
ARP torque
My head gasket is out and I bought ARP headstuds. I need help in torquing my stud ? How many pound should I go ? I have read alot of threads saying 80,70,60,65 what is the best torque specs for boosted stock internals for d17A1? and what is the torquing sequence thanx alot
Old Aug 13, 2008
speedfoos's Avatar
Re: ARP torque
80 ftlbs for boost.
Go buy a Hayne's manual, it has the torque sequence in it. You should not be attempting a head gasket replacement without some sort of documentation to help you along. Also, it's a stepped torque sequence, if you run them to 80 at the first go you will warp the head.
Old Aug 13, 2008
wikkaco0's Avatar
wikkaco0 is an unknown quantity at this point
Re: ARP torque
Head Bolts
Tighten the cylinder head bolts sequentially in 3 steps.
1st step torque: 20 Nm (2.0 kgf/m, 14 lbf/ft)
2nd step torque: 49 Nm (5.0 kgf/m, 36 lbf/ft)
3rd step torque: 67 Nm (6.8 kgf/m, 49 lbf/ft)
Rocker Arm Assembly and Cam Holder
Tighten each bolt 2 turns at a time, in the sequence shown below to ensure that the rockers do not bind on the valves.
Specified torque:
8 mm bolts: 20 Nm (2.0 kgf/m, 14 lbf/ft)
Apply engine oil to the bolt threads.
6 mm bolts: 12 Nm (1.2 kgf/m, 8.7 lbf/ft)
6 mm bolts: (11), (12), (13), (14)
Old Aug 13, 2008
speedfoos's Avatar
Re: ARP torque
Damn it wik. I didn't want to post that! Because then his next thread would be titled "I replaced my head gasket, something broke, my car doesn't run, and I don't know why, help!"
Old Aug 14, 2008
civcspool's Avatar
Re: ARP torque
thanx but thats only upto 67 nm so do i have to do 4 step torque to reach 80?
Old Aug 14, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: ARP torque
i would probably do 5 or 6 steps.
49, 65, then 80. just seems more logical to do it that way rather than from 49 directly to 80. probably warp the head.
whatever you think is easier on the head... i dont think going from 49 to 80 is a good idea though.
Old Aug 14, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: ARP torque
follow This for a PDF file on how to do the head gasket if you need info
Old Aug 16, 2008
wikkaco0's Avatar
Re: ARP torque
If you can take it apart without breaking something, you'll probably be able to put it back together again.
I went in 10 lbs/ft steps over the stock 49 lbs/ft. Do that until you reach your desired torque. The key here is to not warp the head as it has to seat perfectly flat to the deck surface. Use your judgement as you're assembling it.
Old Aug 16, 2008
civcspool's Avatar
Re: ARP torque
yes all done now. but problems keep coming... =( there's no heat coming out but i have ac.. i bleed the whole system for 30 mins any suggestions?
Old Aug 16, 2008
Re: ARP torque
bleed it more. lol
Old Aug 16, 2008
Rufus's Avatar
Re: ARP torque
Ya these cars are retarded with air bubbles
Old Aug 16, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: ARP torque
agreed...i was bleeding mine for two days after i changed my head gasket. might need to do it again though depending on how things work out when i pull the turbo and mani off next week...she seems to be burning a bit of oil at idle (white smoke and smells like oil). i want to blame the turbo seals first since the snail was used and it's been on my ride almost a year now, but we'll see.
Old Aug 16, 2008
andyman97's Avatar
Turbo Guru
Re: ARP torque
Damn, you guys must be doing something wrong then. I do mine for about 15-20 minutes and I'm good to go.
Old Aug 17, 2008
civcspool's Avatar
Re: ARP torque
yes finally!! heater came on i took the hose going to the heater block near the fire wall and started the car for 10 sec and put it back on.
one more question umm my turbo is cooled by oil and coolant sometimes i smell coolant burning on idle boosting or running is that natural?
Old Aug 17, 2008
speedfoos's Avatar
Re: ARP torque
You've got a leak somewhere. Check all your hoses. My craptastic OBX silicone hoses would leak like crazy so I just switched beack to OEM black rubber.
Old Aug 17, 2008
civcspool's Avatar
Re: ARP torque
could that be a possible leak in the head gasket again? but i just changed it? and resurfaced the head
Old Aug 17, 2008
speedfoos's Avatar
Re: ARP torque
I doubt it, just check all your coolant lines and ensure you've got the clamps screwed down tight.
EdGasket
40
Nov 27, 2015 11:11 AM
rovafa2002
Sep 28, 2015 06:57 PM
WaryDriver
Aug 16, 2015 11:22 AM
logsplitter1
Aug 9, 2015 09:32 AM
breanna_17
Jul 21, 2015 04:01 PM
