Confirmation on 2002 Acura EL / Civic Si Brake Torque Specs
Old Aug 10, 2008
babzog's Avatar
babzog is an unknown quantity at this point
Hey folks,
So I'm going to replace the rotors and pads in my '02 EL and wanted to confirm the torque specs for the front and rear caliper mounting bolts and the smaller bolts that I remove to change pads (don't know what those are officially called).
I believe the caliper mounting bolts are torqued to 80ft.lbs and the other bolts are torqued to 24 ft.lbs. Is this common to both the front and rear calipers or are there different settings for each? I believe that this car uses the rear brakes from the same year Civic Si, if that helps.
Cheers!
Jon
Old Aug 11, 2008
DDragon7's Avatar
Re: Confirmation on 2002 Acura EL / Civic Si Brake Torque Specs
I think the smaller slider pin bolts are around 25ft.lbs but I would tighten them just a bit more. I did that to my dad's corolla and the bolt fell off.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
CapYoda
Nov 11, 2001 05:17 PM
