switching alarm outputs?
Old Aug 5, 2008
is it possible to switch the alarm from parking lights to turn signals? like when you lock or unlock the car and the lights flash. i assume its a simple wire tap, but im not very good with alarm stuff and dont have my install manual for it. its a viper600.
Old Aug 5, 2008
D5cIvIc's Avatar
Re: switching alarm outputs?
Can't help, but for sure you can. My parking, signal, sidemarkers, rear turn signals flash when the alarm is either going off or arming/disarming and remote started. viper 791xv btw
Old Aug 6, 2008
well the circuit city guy said it has to be the parking light lol and its not possible to change to signal. so i guess its up to me to figure out again. ill have to dig up the book after i move.
Old Aug 6, 2008
04[ivi['s Avatar
New Member
04[ivi[ is an unknown quantity at this point
It should be a white wire that is fused coming out of the alarm brain that gives out a positive pulse every time you arm/disarm the alarm or when it's going off. That wire is tapped into the parking lights because the parking lights light up all the way around the car. I dont see how you can do just the turn signals because both seperate wires. Maybe splice into both of them since theres left and right?
Ideas anyone?
Old Aug 7, 2008
i think that would work but i thought of something else, it might be too much wattage for the single small wire. 21wx4=84w is more than a halogen headlight bulb. so idk... maybe its a bad idea.
Old Aug 7, 2008
Alpha 5's Avatar
You can do this.
You will have to use a couple relays and a diode or two....
You are smart and will figure it out.
Old Aug 7, 2008
thanks for the ideas, makes sense
Old Aug 7, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
The wire you want to tap into is green/white coming out of the hazard switch. It looks like the relay the grn/wht feeds into has the "flasher" circuit built into it. The wire is positive trigger.
You should be able to move the white from the alarm to that instead of park lights. The only unknown then is will it flash correctly. My guess is it will.
File Type: pdf
dtdoyle
25
Aug 30, 2015 06:57 PM
Mucklow
Aug 22, 2015 06:28 PM
JetsterDajet
Aug 16, 2015 01:56 PM
mrwhos
Aug 11, 2015 02:03 AM
