front sway bushing size?
Old Jul 28, 2008
anyone know what the stock size is, i dont think 1 inch is correct like what this site says. for 01-04 civic
http://nipponpower.com/product.phtml?p=324&mmk=392
Old Jul 29, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: front sway bushing size?
https://www.civicforums.com/forums/4...ease-read.html
http://www.geocities.com/bellz252/ar...ybarspecs.html
Old Jul 29, 2008
FALKEN's Avatar
Civicforums Junkie
The 2001s came with the 25.4mm bar
Ive got the Energy Suspension Polyurethane bushings on my 01 EX Sedan...feels much better than the stock setup
Old Aug 6, 2008
bump, i forgot the size, but its clearly printed on the stock bushing. the problem tho is that the stock one is not a normal bushing shape like the rear. it has a different design. so idk if its possible to cut chunks out of the ES bushing to mod it in there or if i should just get new oem bushings to replace the cracked ones.
Old Aug 6, 2008
TRIZ's Avatar
I can check my 01 bar size if that helps you. I still got the OEM bushings- took the bar off, sitting in the attic. Hit me up if you want me to dig em up and grab whatever numbers u need off them.
Old Aug 6, 2008
well thats not the problem, i found the size on the side of the bushing. problem is weird shape. its not flat on the bottom is rounded off on each side.
Old Aug 7, 2008
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
maybe its to give it some sideways movement.
but i am not sure, i just dont realy see a problem.Its gets mounted agains a flat side so.
If i allready had my energysuspions ones(04-05 TSX type are 25.4mm) i could tell you if they are flat.
I swapped my 15.4mm to 25.4mm but still with
Oem bushing and yes they are rounded.
Old Apr 23, 2009
so the 1 inch i just got did not fit, too loose. the stock one on my 2002 civic ex sedan is something like 0.874 inch or 22mm. anyone know what size i should order? im still trying to get ahold of someone to send these back but idk what else i should get instead.
Old Apr 23, 2009
okay so the 03 rsx ES front sway bushings are 23mm which is close enough. anyone know if they have that same shape with the indented top part instead of flat?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
GolNat
Sep 10, 2015 08:25 PM
bsmiley
Apr 27, 2015 01:27 PM
