1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
'92 DX randomly stalls, hard to restart
Old Jul 7, 2008
F14CRAZY's Avatar
F14CRAZY is an unknown quantity at this point
Hi guys, my dad has a '92 DX sedan, manual trans. It runs great otherwise with no CEL codes.
It will randomly stall while driving and won't restart unless you wait a few minutes, or just won't restart after being driven. It starts fine when cold.
It turns over just fine but won't take off. It seems to do it maybe once a day. After waiting the few minutes and trying it again, it starts normally and runs perfectly fine.
The other day when it happened he was in slow/stopped traffic, and today it wouldn't restart after he turned it off at a store.
Any suggestions guys?
Old Jul 7, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: '92 DX randomly stalls, hard to restart
I got a few.
1. Drop the gas tank, pull out the fuel pump and try to blow through it with your mouth. If you can't get gas coming out the other end, your fuel pump is either bad or blocked. And even if you can, put a voltimeter on it to make sure it's getting power.
2. Are his dash lights at normal brightness? That will tell you problems with your alternator/battery. If this is the case, sometimes turning off all accessory power (radio, dome light, dash lights) will give enough power for the car to start before taking it to a mechanic. Or simply buying a new battery/alternator.
3. It could simply just be the fuel lines themselves. Is this car old enough to be carburated or did they have fuel injection then? Try the injectors.
I've dealt with beater cars not starting many times, my dad's owned 2 Escorts, a Cavalier, Spirit, Blazer, Explorer and now an Escape. He's a sucker for crappy domestics.
EDIT - I forgot to state the obvious. Turn the key to the ON position without starting the car and listen real carefully for the fuel pump to come on. If you don't know what you're listening for, get in someone else's car and listen to it, then get in your dad's. If there's no sound, there's no pumping.
Old Jul 13, 2008
F14CRAZY's Avatar
I found it to be the fuel pump relay...I removed the back seat and found that power was not going to the pump when it wouldn't start.
Old Jul 14, 2008
DeX's Avatar
DeX
Canadian, Eh!
Boyakasha, plus one for me.
Old Jul 14, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
i was going to say main relay. VERY common problem on 4-5gens.
Old Jul 14, 2008
F14CRAZY's Avatar
I did the quick test of spraying some ether in the thing...it would run on ether so I traced it from there with a test light
Old Nov 10, 2008
larryjoe817's Avatar
larryjoe817 is an unknown quantity at this point
I Had the same problem, look under your dash and it's gonna be your MAIN FUEL RELAY, It's a box about 2"x1-1/2" big with a wire harness and it's labeled, it's about $80 bucks at autozone, but just get it from the wrecking yard.
Old Nov 11, 2008
DeX's Avatar
DeX
Canadian, Eh!
Originally Posted by larryjoe817
I Had the same problem, look under your dash and it's gonna be your MAIN FUEL RELAY, It's a box about 2"x1-1/2" big with a wire harness and it's labeled, it's about $80 bucks at autozone, but just get it from the wrecking yard and put it in your pocket.
Great first post, douchebag, quit telling people to steal. Better yet, quit bringing up threads that are 4 months old.
SimpleUser
Apr 24, 2021 02:54 AM
Valkman
Aug 13, 2015 04:19 PM
2010 Civic
Aug 10, 2015 10:53 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
