Pro-Kit v.s. H&R Sports
Old Jun 20, 2008
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Which springs do you guys think are softer? I already have Bilstein struts and Hotchkis 25.4mm sways and now I just want to compliment them with a MILD drop of about an inch. I was leaning towards the H&Rs because I had them on my S2000 and they weren’t bad, but im not sure if they are the way to go now. With the Bilsteins my car is already pretty firm on stock springs so I don’t want anything a lot stiffer. Thanks for the input...
Old Jun 20, 2008
dopes6070's Avatar
Re: Pro-Kit v.s. H&R Sports
OOh and if anyone has pics of either drop on a sedan with aftermarket struts please post them.
Old Jun 20, 2008
prokit and tokico hp shocks. very good ride quality. 2 finger gap all around
Old Jun 20, 2008
spoonEM's Avatar
omgwtfbbq mod.
Id say the Eibach's are going to be the softer spring. When I had them on my coupe, I was actually shocked (no pun intended) at how smooth they were.
Old Jun 20, 2008
dopes6070's Avatar
Hey what is your tire size on that pic gearbox?
Old Jun 20, 2008
dopes6070's Avatar
rob you HAVE to come over and check out the way my car drives with the new sway bars lol...
Old Jun 20, 2008
spoonEM's Avatar
omgwtfbbq mod.
haha...for sure. i got sick, but if i feel better ill cruise by this weekend sometime.
Old Jun 20, 2008
15 inch rims, stock tire size (fuzion hri). idk what the deal is with that, people ask me all the time if the rims are 16s and what kind of special tires. lol they are all stock fatty size lmao. nothing to see here folks. and why do people love the way this tire looks? omg, it looks like any other tire i see.
Old Jun 20, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
h&r sport, least drop - best rates
Old Jun 21, 2008
TemjinX2's Avatar
i believe the eibachs are softer. Why not just email both manufacturers and ask for the spring rates. It'll be more accurate then going off someone else's butt dyno.
i couldn't find one on 7th gen. found some spring rates on the 6th, but you can probably assume they'll be similar to the 7th gen.
I would email the manufacturers to get concrete numbers but they should give you an idea.
Heres a list of spring rates for Civics
For 96-00 Civics (EJ6-8 and EM1 chassis codes)
96-00 EX - 165F/80R (P/P)
99-00 Si (EM1) - 201F/99.8R (P/P)
97, 00-01 ITR - 250F/250R (L/P)
GS-R - 200F/95R (P/P)
CTR - 240/240 (L/P)
H&R OE - 280F/190R (P/P)
Eibach ProKit - 290F/190R (P/P
H&R Sport - 330F/280R (P/P)
Eibach Sportline - 310F/275R (P/P)
Gold-line GL 2.5" drop - 320/190 (P/P)
Gold-line GPS 1.25" drop - 275/160 (P/P)
Koni RSK Suspension kit - 154-205/270 (P/L)
Neuspeed SofSports - 260F/150R (P/P)
Neuspeed Sport - 280F/180R (P/P)
Neuspeed Race - 485F/395R
Skunk Coilovers -old - 400F/300R (L/L) for civic, 500F/400R for integra
Skunk2 Coilovers - new - 500F/400r (L/L)
Spoon Full Coilovers - 300/240
Progress Coilovers - 350F/250R (P/P)
Progress Lowering Springs - 320F/200R (P/P)
Ground Control Coilover - 380F/280R (P/P) (this is the standard kit and the springs are mildly progressive).
Tein RA/RE/RS - 783F/559R (L/L)
Tein HT - 1119F/448R (L/L)
Tein HG - 365F/129-196R (L/P)
Tein SS - 448F/224R
Tein Flex - 504F/280R
Tein S. Tech - 235F/140R
Tokico Illumina Kit - 250/123 (P/P)
APEX'i WS - 447f/178r
Suspension Techniques - needed
SSR Cup - 392/280
SSR S1 - 448/448
JIC FLT-A2s - USDM - 504F/336R (L/L)
Sparco - needed
For 02+ Civic Si (EP3): ~ Very special thanks to Mike (EXavier) for these!!!
Progress - 280F/500R
Eibach Pro-Kit- 15-20% stiffer then stock
Eibach Sportlines - 20-25% stiffer then stock
Sprint - 20-25% more then stock
H&R Sport - 25-30% more then stock
Tein SS - 336F/448R
Tein Flex - 448F/559R
Tein S. Tech - 157F/291R
P = Progressive
L = Linear
Old Jun 21, 2008
dswami1's Avatar
dswami1 will become famous soon enough
both are progressive springs, they dont have linear spring rates.
Old Jun 21, 2008
TemjinX2's Avatar
just because there progressive doesn't mean they dont have spring rates. look at the list half are progressive and have spring rates.
Old Jun 21, 2008
MrXclusivE's Avatar
h&r sports are like 350 spring rates, and they still ride very comfortable
Old Jun 21, 2008
Kirie's Avatar
Kirie is an unknown quantity at this point
what does the numbers means?
Old Jun 21, 2008
TemjinX2's Avatar
Spring Rate is the amount of weight needed to compress a spring a certain . Springs are rated in LB/in (in metric system kg/mm), or specifically, how many pounds of weight are required to depress the spring by one inch.
With a linear spring, the spring becomes linearlly stiffer as you take the car to its limit.
With a progressive spring the spring becomes expondentially stiffer as you take the car closer to the limit. Benefit to a progressive spring is that you can get away with a softer spring for daily driving but still have the stiffness when at the limit.
The benefit to a more linear spring is that fact its easier to predict how the car will behave.
For example, you'll notice the integra type R has a linear front and a progressive rear stock. When you get serious with suspension you can play with the spring rates, hence why people like buying gc coilovers because you can go with custom spring rates.
Old Jun 21, 2008
hmm maybe go with H tech springs from tein? but its not gonna be very low at all, kinda a waste for less than 1 inch.
Old Jun 21, 2008
dopes6070's Avatar
ya I want like an inch because the bilsteins made the rear of my car sit a little higher then it was stock lol.
SammySC
121
Apr 7, 2017 07:43 PM
Tedverseti
Sep 29, 2015 05:41 PM
krazykoncepts
Sep 8, 2015 09:02 PM
