Pro-Kit v.s. H&R Sports
Which springs do you guys think are softer? I already have Bilstein struts and Hotchkis 25.4mm sways and now I just want to compliment them with a MILD drop of about an inch. I was leaning towards the H&Rs because I had them on my S2000 and they weren’t bad, but im not sure if they are the way to go now. With the Bilsteins my car is already pretty firm on stock springs so I don’t want anything a lot stiffer. Thanks for the input...
Re: Pro-Kit v.s. H&R Sports
OOh and if anyone has pics of either drop on a sedan with aftermarket struts please post them.
Id say the Eibach's are going to be the softer spring. When I had them on my coupe, I was actually shocked (no pun intended) at how smooth they were.
rob you HAVE to come over and check out the way my car drives with the new sway bars lol...
15 inch rims, stock tire size (fuzion hri). idk what the deal is with that, people ask me all the time if the rims are 16s and what kind of special tires. lol they are all stock fatty size lmao. nothing to see here folks. and why do people love the way this tire looks? omg, it looks like any other tire i see.
i believe the eibachs are softer. Why not just email both manufacturers and ask for the spring rates. It'll be more accurate then going off someone else's butt dyno.
i couldn't find one on 7th gen. found some spring rates on the 6th, but you can probably assume they'll be similar to the 7th gen.
I would email the manufacturers to get concrete numbers but they should give you an idea.
Heres a list of spring rates for Civics
For 96-00 Civics (EJ6-8 and EM1 chassis codes)
96-00 EX - 165F/80R (P/P)
99-00 Si (EM1) - 201F/99.8R (P/P)
97, 00-01 ITR - 250F/250R (L/P)
GS-R - 200F/95R (P/P)
CTR - 240/240 (L/P)
H&R OE - 280F/190R (P/P)
Eibach ProKit - 290F/190R (P/P
H&R Sport - 330F/280R (P/P)
Eibach Sportline - 310F/275R (P/P)
Gold-line GL 2.5" drop - 320/190 (P/P)
Gold-line GPS 1.25" drop - 275/160 (P/P)
Koni RSK Suspension kit - 154-205/270 (P/L)
Neuspeed SofSports - 260F/150R (P/P)
Neuspeed Sport - 280F/180R (P/P)
Neuspeed Race - 485F/395R
Skunk Coilovers -old - 400F/300R (L/L) for civic, 500F/400R for integra
Skunk2 Coilovers - new - 500F/400r (L/L)
Spoon Full Coilovers - 300/240
Progress Coilovers - 350F/250R (P/P)
Progress Lowering Springs - 320F/200R (P/P)
Ground Control Coilover - 380F/280R (P/P) (this is the standard kit and the springs are mildly progressive).
Tein RA/RE/RS - 783F/559R (L/L)
Tein HT - 1119F/448R (L/L)
Tein HG - 365F/129-196R (L/P)
Tein SS - 448F/224R
Tein Flex - 504F/280R
Tein S. Tech - 235F/140R
Tokico Illumina Kit - 250/123 (P/P)
APEX'i WS - 447f/178r
Suspension Techniques - needed
SSR Cup - 392/280
SSR S1 - 448/448
JIC FLT-A2s - USDM - 504F/336R (L/L)
Sparco - needed
For 02+ Civic Si (EP3): ~ Very special thanks to Mike (EXavier) for these!!!
Progress - 280F/500R
Eibach Pro-Kit- 15-20% stiffer then stock
Eibach Sportlines - 20-25% stiffer then stock
Sprint - 20-25% more then stock
H&R Sport - 25-30% more then stock
Tein SS - 336F/448R
Tein Flex - 448F/559R
Tein S. Tech - 157F/291R
P = Progressive
L = Linear
CTR - 240/240 (L/P)
Tein SS - 448F/224R
SSR Cup - 392/280
SSR S1 - 448/448
Sparco - needed
Tein SS - 336F/448R
P = Progressive
L = Linear
Spring Rate is the amount of weight needed to compress a spring a certain . Springs are rated in LB/in (in metric system kg/mm), or specifically, how many pounds of weight are required to depress the spring by one inch.
With a linear spring, the spring becomes linearlly stiffer as you take the car to its limit.
With a progressive spring the spring becomes expondentially stiffer as you take the car closer to the limit. Benefit to a progressive spring is that you can get away with a softer spring for daily driving but still have the stiffness when at the limit.
The benefit to a more linear spring is that fact its easier to predict how the car will behave.
For example, you'll notice the integra type R has a linear front and a progressive rear stock. When you get serious with suspension you can play with the spring rates, hence why people like buying gc coilovers because you can go with custom spring rates.
hmm maybe go with H tech springs from tein? but its not gonna be very low at all, kinda a waste for less than 1 inch.
ya I want like an inch because the bilsteins made the rear of my car sit a little higher then it was stock lol.
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
