Andy was right! It was my headgasket!
Don't mean to stroke your ego bro, but you nailed it....
Head is off to get milled this time.
Re: Andy was right! It was my headgasket!
Dude, my ego isn't big. I just like to talk cars, esp. mechanics. And I have had every symptom you can imagine. But seriously, you ****ers need to listen to me when you're having problems.
When you put it back together, make sure you retorque to 80 ft/lbs and find a good tuner. Don't boost at all until you do.
Naw. My advice still stands. Never listen to Andy, he has no idea what he's talking about...
I've seen that exact thing on so many headgaskets on my car it makes me sick. I hate changing HGs. Check the block to make sure it's true as well.
The car has a good tune. Joe at Locash racing is one of the best Honda tuners around.
I had to remove the studs too. How the hell do I torque those down? Should I just turn them with an allen head until tight? The actually nuts I can tighten in sequence to 80lbs, that part is easy enough.
Tell me why the gasket is getting eaten up on the intake side. Even the pistons are clean in the back.
One of two things:
Detonation
Head lift from power; not enough torque on the studs
Yeah, just hit the studs with an allen key until they won't turn anymore and torque in sequence to 80. Make sure you use moly lube on the stud threads on both ends.
Pistons are clean because coolant is steam cleaning them, lol.
I don't know **** about your setup. Fuel system is important, your pump could be fading, it could be that your injector duty cycle is too high and they're starting to go. It could be that Joe isn't being thorough enough on your tune and your timing is advanced too much in the upper rpms. This isn't a problem I can likely diagnose over the net. You need to know what's going on with your ****.
Detonation
I'll be the first to admit that I'm running a stock fuel setup minus those SRT injectors. However, others have done it successfully. Not sure why it's killing me.
Those injectors are huge how are they maxing duty cycle?
**** it, I want a G35. lol
Because your stock fuel pump sucks fat ****ing ***** and can't support enough fuel flow to feed the injectors, holy ****, no wonder you're having problems. Successfully? I haven't seen anyone much over 200 whp with a stock pump, that's one of the first upgrades you should do.
How are you maxing duty cycle? Because your pump isn't keeping the volume needed for the injectors to compensate and keep your afr's where they need to be. Hence, your tuner is cranking your injectors up, trying to compensate the only way he can and it's maxing them....
Don't be mad at the car, it isn't the poor car's fault you didn't do the necessary fuel upgrades, lol. This is exactly what is meant when you talk about reliability in a boosted car, you have to have the necessary mods to support the power you're trying to make.
I'm only at 175WHP and I'm happy with it. So just to clarify, I need to upgrade my fuel system just to run 175WHP?
Ok I just wanted to hear you say it.
Can I just pick up a Walbro without the return conversion?
What do you have for fuel management? If you have the PCS XFC with the fuel pump kit you can increase the fuel pressure and this will help tuning.
I have Kpro and I have adjusted fuel before. I actually had to for idle. Andy's thought process is that the pump can't hang though. Hell a Walbro is $100 shipped. I have no problem with that, but if it takes another $500 to get this thing back to being safe it's going up for sale and turning into a down payment for a white G35 coupe on some black 19's with a giant lip.
I bet money you'll be spending more than $500 for the rest of the year. It's turbo though doesn't this come with the territory? Good luck with the setup though I forgot you had kpro.. get that walbro though.
I just did some research. I can't use the stock FPR. Even if I can it sounds like it doesn't change anything. So how much is this damn FPR?
This car is pretty reliable minus this one issue.
Isn't Foos running a stock pump still?
No way, he isn't on a stock pump at 270 whp, no possibility a stock pump would handle that.
I'm not saying that the pump is certainly your issue but it definitely isn't helping. You can run the stock regulator, nothing wrong with it. If you're happy with 175 whp, just find the place you're having issues. Don't you have a wideband? You have to keep an eye on it and make sure you can keep up with fuel demands....
Ah I saw an old post. My point is that if I wanna stay at or under 200whp is a FPR necassary or can I just stick with a returnless fuel setup and a Walbro?
I need this o2 setup immediately.
Hey an o2 would at least tell if I'm having fuel problems.
Just dropped off the head for a mill and valve job.
Yes, I'm running a Walbro on the stock FPR and returnless setup. It's been fine, but I'm changing the setup when I get back on the 23rd to an FPR and return setup.
Yeah, fittings are a pita. I won't skimp on fuel hose again
****ing jeg's proflo 250 dry rotted on my ***. Time for the aeroqup, real deal!
cyc
Jul 22, 2015 01:14 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
