coil-over shock thrust bearing
Old Jun 2, 2008
exturbo6's Avatar
http://store.summitracing.com/partde...t=hal-7888-109
ok, so im replacing my suspension, and i bought me a set of these bearings...but i have a problem, they dont fit where the stock bearings do...the diameter of the bearing isnt like the stock ones. they are smaller in roundness. any help would be great thank you!
Old Jun 2, 2008
Zzyzx's Avatar
Autocross Junky
Re: coil-over shock thrust bearing
I assume you are trying to change the strut bearing? if so, you've purchased the wrong part. These are designed to sit on the lower perch of an adjustable spring. something like Ground controls.
as such they will pretty much be worthless for a stock type suspension (lowering springs)
Old Jun 2, 2008
exturbo6's Avatar
i have skunk2 coilover sleeves.
Old Jun 4, 2008
Zzyzx's Avatar
Autocross Junky
And you are trying to mount these on the lower spring perch right?
did you get the correct ID? most springs, such as skunk2's are 2.5 ID (Inner Diameter)
Bonobo
Oct 2, 2015 06:58 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Elciteeve
Sep 28, 2015 12:40 PM
Bruce2
Sep 27, 2015 08:45 PM
