Minimum engine modifications to mount a turbo
Old May 24, 2008
Vertigo Jones's Avatar
Vertigo Jones is an unknown quantity at this point
Chewing through everything I can find to see what can actually be done to to a D series SOHC VTEC, the most common suggestion is "get a different engine", However, one thing I have found is that both Turbo and supercharger kits are available that would "fit". However, therea a big stumbling block.
The D15Z6 has very little in the way of upgrades for Rods, cams, pistons or anything else, So, my query is this :- Just how bad is fitting a turbo or SC when retaining most of your stock engine innards?
Old Jun 14, 2008
sql_civic's Avatar
Re: Minimum engine modifications to mount a turbo
You can keep your stock innards if you stay below 200 HP.
Old Oct 8, 2009
jimbolina25's Avatar
jimbolina25 is an unknown quantity at this point
do you need to reprogram the ecu to fit a turbo?
Old Oct 8, 2009
OCDjG's Avatar
OCDjG will become famous soon enough
You definitely want to get some kind of tuning control with your turbo. Check out this forum here...
http://www.d-series.org/forums/
You'll find all the info you need there.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
cloudguy
Apr 28, 2015 05:02 AM
bsmiley
Apr 27, 2015 01:27 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
