98 keyless trouble
Old May 23, 2008
akaias's Avatar
akaias is an unknown quantity at this point
98 keyless trouble
My trusty 98 Civic has an odd problem with the keyless entry.
It stopped working quite some time ago and I didn't bother with it, just went to using the manual key (the battery was fine).
I recently dug out the spare remote I got with the car and it works so-so. The panic button works as does the unlock button. The lock button doesn't. I have reprogrammed the remote to the car and still no lock. (The original remote is dead, it doesn't reprogram, no buttons work, and battery is at 2.9V)
If I remote unlock the car, then hit the lock button the dome light shuts off but the doors do not lock. The battery is a 3.0V.
Also the power locks work fine using the switch in the car. All fuses are ok as well.
I have tried searching and haven't found much on this issue.
Does anyone have any ideas as to what the problem may be?
Old May 28, 2008
LTFA182's Avatar
LTFA182 is an unknown quantity at this point
Re: 98 keyless trouble
I had a 98 too and my remote also sucked. It would work once in awhile even after i replaced the battery. If your doors aren't locking check to see if the locks are actually locking all the way, my passenger side would need a few clicks to actually get it in place.
h4ldol
Apr 24, 2017 08:16 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
Bruce2
Sep 21, 2015 08:01 PM
