98 keyless trouble
98 keyless trouble
My trusty 98 Civic has an odd problem with the keyless entry.
It stopped working quite some time ago and I didn't bother with it, just went to using the manual key (the battery was fine).
I recently dug out the spare remote I got with the car and it works so-so. The panic button works as does the unlock button. The lock button doesn't. I have reprogrammed the remote to the car and still no lock. (The original remote is dead, it doesn't reprogram, no buttons work, and battery is at 2.9V)
If I remote unlock the car, then hit the lock button the dome light shuts off but the doors do not lock. The battery is a 3.0V.
Also the power locks work fine using the switch in the car. All fuses are ok as well.
I have tried searching and haven't found much on this issue.
Does anyone have any ideas as to what the problem may be?
Re: 98 keyless trouble
I had a 98 too and my remote also sucked. It would work once in awhile even after i replaced the battery. If your doors aren't locking check to see if the locks are actually locking all the way, my passenger side would need a few clicks to actually get it in place.
h4ldol
Apr 24, 2017 08:16 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
Bruce2
Sep 21, 2015 08:01 PM
