1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
'92 sedan brake issues
Old Apr 28, 2008
F14CRAZY's Avatar
F14CRAZY is an unknown quantity at this point
I've been working on my dad's 92 DX sedan (manual)...it started a few days ago when he decided to have me change his front pads and rotors because they were warped...I picked up some good ones from Advance and installed them along with bleeding all 4 as a maintenance thing...16 y/o brake fluid isn't that great.
So, we both try it out, and the pedal goes to the floor. They seem to be working ok but the pedal travel is just really long. Both of us have bled the lines on a dozen or so different times on various vehicle so you know ...we know what we're going as far as that goes. So I figure I may have air in the lines somewhere, so we bleed it again, starting at the pass. rear, driver's rear, pass front, driver's front...no change.
We then figure that perhaps the master cylinder went bad at the same time. He hasn't owned the car very long but the master appears to be pretty fresh. At any rate we get another from Advance, bench bleed, install, and bleed all the lines again...this time, it seems that the pedal will go to the floor when you initially pump it, but after that it will be fine. After not pressing the brake for about 20 seconds, the pedal will go to the floor again, but again, its fine after that first pump. Bled the lines again, no change.
After this we decide to take it to our local mechanic who's worked on this Civic and another twin before. He tried the old master cylinder of ours again, no change. He then figured to replace the vacuum booster drum thing... though now it seems that he thinks only the front brakes are working in addition to the 20 second issue. He messed with the car for 6 hours and he's an experienced, honest mechanic. He's proceeding to send it to a nearby shop that specializes in brake systems (and not charging us for the 6 hours, though my dad insists he receive a little for his time).
What do you guys think of this situation? Thanks.
Old Apr 28, 2008
F14CRAZY's Avatar
Re: '92 sedan brake issues
BTW I thought I'd also say that we have not found any leaks in the lines, calipers, or bleed screws
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
McD
Apr 29, 2015 03:50 PM
rac53041
Dec 6, 2001 03:39 PM
Sparty
Nov 15, 2001 04:55 PM
