car overheated
Old Apr 27, 2008
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
car overheated
okay i just recently (2 days ago) did a lil maintance at home, changed
motor oil (3.5 qrts)
tranny oil (drain not flushed) and ( 3 qrts )
spark plugs (ngk)
i was sitting in traffic and i looked at the cars temp and it climbed all the way up to HOT. i was so i turned up the heat and it went back down again.
why did my car overheat? is it kus i didnt put enought oil or tranny oil?
Old Apr 27, 2008
colourwolf's Avatar
colourwolf will become famous soon enough
Re: car overheated
I say check if the thermostat is stucked at closed position.
Old Apr 27, 2008
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
Re: car overheated
acutally, i just had the exact same problem.... except turning up the heater didnt help for me. found out that the upper hose was hot, but the bottom radiator hose was cool along with my radiator core. my thermostat wasnt opening. decided to drain the fluids and after i did, it was running just fine again. perhaps a build up in the radiator and jammed the thermostat.
but yeah, check your hoses to see if they are up to temp
Old Apr 27, 2008
mrbanhbao's Avatar
Re: car overheated
oh alright so you guys dont think its the lack of my motor oil or tranny fluid?
Old Apr 27, 2008
D5cIvIc's Avatar
Re: car overheated
^no it's not
Old Apr 27, 2008
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Re: car overheated
Get the thermostat out and put it in hot
water it should open close to 90degrees.
Old Apr 27, 2008
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
Re: car overheated
^what he said
Old Apr 27, 2008
mrbanhbao's Avatar
Re: car overheated
haha the funny thing is i dont even know where that is located in the car.
Old Apr 27, 2008
You VTEC...I-VTEC
Re: car overheated
it is located where i circled in red
Old Apr 27, 2008
Re: car overheated
the bottom hose should not be getting very hot or the radiator is not cooling the fluid properly.
Xuhme
21
Aug 7, 2023 03:40 PM
ChristinaVHH
May 10, 2015 03:51 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
