Tuning My 89 Civic
hi i have an 1989 honda civic dx hatchback i planned on doing a tune up on it. i havnt done any mods to it. its the only car i have its all stock. i need to know what spark plugs would be best to use?? i was going to go with ngk v power. and also what spark wires to use. i was told get the wires from a dealer oem's i beleive. not sure what that means. is oem the brand name?
thanks in advance.
thanks in advance.
Re: Tuning My 89 Civic
OEM is Original Equitment Mfgr, meaning buy the company that made your car- honda.
If you want to stick with NGK, you have several options- they even make plug wires. I'd stay away from iridium plugs, and platinum is a little overkill.
For wires, you basically want something that isnt going to rust, something that is sealed, and can flow the signal to the plug effectively. Many companies make wires, there really isnt one that is the best- honda is reliable, but there are aftermarket plugs out there that can do a better job- honda parts arent ALWAYS the best.
1989 HONDA CIVIC DX 1.5 L4 D15B2 FI Plugs - SOHC
Spark Plug Part No. Stock No. Plug Gap
Standard BCPR6ES-11 6779 .044
V-Power BCPR6E-11 # 5632 .044
G-Power Platinum BCPR6EGP 7088 .044
Laser Platinum BCPR6EP-11 * 3350 .044
Iridium IX BCPR6EIX-11 4919 .044
* Premium Laser Plug # Original Equipment
Wire Set Part No. Stock No.
Wire Set HE53 9988
Wire Set HE53 9988
im confused right now sum1 told me that my car isnt a dx. its a 4 speed so its an std. it says dx on my hatch so i assumed it was. and on my engine it says 16 valve. so what do i have? its a 16 valve 4 speed honda civic hatchback dx or not?
easiest way to find out for sure is to plug your vin number into carfax.com and get a free report... it'll tell you, its the end all to the question "what kind of car do i have?"
could be an engine swap. look on the side of the block for a stamped letters starting with D16 , D15 , B16, B18 etc. something thats starts with a D or a B most likely then you will know what motor and there should be two digits more after the 15-18 parts. that will give the the engine code then you can search wiki and it will tell you what that engine is from. its common to see older civics that have a motor from a similar civic thats a little newer even though it will still look stock in there.
i cant find it. theres alot of oil on my engine i need to change my valve gasket. i wiped sum of it off but i couldnt find it. can u post a pic of the 2 cars engines? the 1989 civic hb dx an the std?
ashleymmackey
Apr 18, 2015 09:48 PM
chgofirefighter
Apr 18, 2015 08:08 PM
CapYoda
Nov 11, 2001 05:17 PM
