Civic sitting crooked
Old Apr 21, 2008
Kojak's Avatar
Kojak is an unknown quantity at this point
Question Civic sitting crooked
I had noticed for a while that my 1996 civic was sitting kinda crooked. The passenger front had the biggest gap between the tire and fender and the drivers side rear was the lowest. I replaced the shocks and springs and nothing changed. So I replaced the bushings in the rear and still nothing. What am I missing? Any input would be greatly appreciated!
Old Apr 22, 2008
sql_civic's Avatar
Re: Civic sitting crooked
Check that the ball joint on the LCA is properly installed and the the UCAs aren't shot.
Old Apr 23, 2008
Kojak's Avatar
Hey thanks for the reply, but please pardon my ignorance. What ball joint are you refering to, and what is a UCA?
Old Apr 24, 2008
sql_civic's Avatar
UCA = upper control arm.
There's a ball joint in the lower control arm that connects to the steering knuckle. It could possibly be not fully seated. The UCA ball joint could be pressed out of it's fitting if it's really messed up.
Old Apr 25, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
and i think he's referring to the front lower control arm (LCA). not sure which side, but i would have it all checked out. you may also have a blown shock on the driver's side rear.
Old Apr 30, 2008
clkelly's Avatar
clkelly is an unknown quantity at this point
I also have a 96 civic doing the same thing. I don't think that a shock would cause the car to sit lower. It would seem that the spring would control the height. I am in the process of replacing my springs. Will probably at that time look at the bushings, as they are squeeking some now.
If anyone has other ideas let's hear them.
Old Apr 30, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Are you sure your springs are the same size all the way around? If someone half assed a repair, it could cause this.
Old Apr 30, 2008
Kojak's Avatar
Hey guys thanks for the replies. I went out today and checked it out... all the joints and stuff are fine. The springs are Tein H-tech's, which I installed myself... so they are definitely all the same height. I still don't get it... starting to really bug me...
Old Apr 30, 2008
ONE7thREBUILT's Avatar
ONE7thREBUILT has a spectacular aura aboutONE7thREBUILT has a spectacular aura about
Maybe the frame is twisted.
Old May 1, 2008
Kojak's Avatar
Yikes! How do I tell if the frame is actually twisted?
Old May 1, 2008
Park on a very flat surface and measure the distance from frame to ground at different spots on each side and compare.
Old May 1, 2008
or goto a bodyshop lol
Runner88
Mar 2, 2023 04:54 PM
roverben
Jan 21, 2019 05:16 PM
mikemc422
Aug 9, 2018 05:41 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
gabrown2
Apr 11, 2015 08:22 PM
