93 Civic Si Coupe 5 Speed
Yes i just bought this car and im not to familiar with the whole import thing but when i have it in first and second it makes a noise as if i was grinding the gears? what could cause this ? is it that the gears are actually grinding or what ?
Re: 93 Civic Si Coupe 5 Speed
Honda didn't make a 93 Si coupe. Do you mean that you have the d16z6 engine in a 93 coupe?
Anyway, the noise that you're hearing could be a number of things, but more than likely its a bad synchro mesh between gears. You can drive for a long time with a bad synchro, as long as you aren't raping it between the gears that that synchro is bad in.
lilbluecivic
Nov 7, 2001 06:49 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
