Front Brakes and Rotors
Old Apr 5, 2008
JKoffler44's Avatar
JKoffler44 is an unknown quantity at this point
I am about to change the pads and rotors on my girlfriend's 01 EX. I was wondering if I have to disconnect the brake line to change rotors like the Haynes manual says? I've never bled brakes before and would like to avoid it since I just had them bled a month ago.
Thanks!
Old Apr 5, 2008
DsevenEm2's Avatar
This is Myspace
Re: Front Brakes and Rotors
no you dont have to.. just loosen the caliper and lift it up. Use a wire to suspend the caliper in the air and attach the other end to the spring or something. make sure not to bend or crimp the brake line.. just leave it suspended while you removed the rotors..
Old Apr 5, 2008
JKoffler44's Avatar
Is an impact screw driver necessary? I can't find one anywhere!
Old Apr 5, 2008
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
dont leave the caliber suspended....just support it w/ something like a can of paint *perfect height* while ur working on the rotors
Old Apr 5, 2008
DsevenEm2's Avatar
This is Myspace
It really doesnt matter...suspended or supported.. same difference.
You should only need a hammer and a no.3 phillips for taking off the rotor, but I would highly suggest an impact wrench or gun for loosening the calipers. Mine were stuck on there hardcore.. only air tools would get them off. An impact screwdriver you could use for the rotors but I dont think you actually need it..
Old Apr 5, 2008
JKoffler44's Avatar
The calipers were fine, I needed a giant 1/2 inch drive ratchet and some PB Blaster to get them off. The rotor screws were a pain and almost stripped. Then I finally found out that Sears had an impact screwdriver. I don't know why I didn't go there first! After that it was a piece of cake.
Thanks for your help!
Old Apr 6, 2008
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
read this if you are talking about those two philips head screws
https://www.civicforums.com/forums/7...ml#post4196465
screwing two long bolts into the holes works like a charm and doesnt damage anything
Old Apr 6, 2008
sl33pyriceboi's Avatar
its only necessary if u cant take off those stubborn two screws on teh rotor...
but a impact screwdriver makes ur life a HELL lot easier...its like 15bucks...
also, as for rotors, id highly suggest getting oem...and not other stuff like bembo blanks (which suck)
stick with oem, its cheap and the best blank rotors...and get some hawks HP plus pads....then ur makes will drastically improve...
Old May 29, 2008
Matt300's Avatar
Matt300 is an unknown quantity at this point
You shouldn't have to disconnect the lines. Thank God Honda loves us like this. I had a Dodge Dynasty, Ford Escort, and Mitsubishi Lancer before my Civic. You had to take the lines of for EVERYTHING. Pain in the ***. Just have something to loosen the calipers if they're stuck or go straight to the impact screwdriver. It's pretty easy to strip something and then you're really screwed.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
tattedlariat
Apr 12, 2015 07:55 PM
