clocking a t25?
Old Mar 10, 2008
dust's Avatar
dust is an unknown quantity at this point
clocking a t25?
Hey guys Im using a t25 turbo and I during a mock up installation I found out that i need to clock the turbo so the inlet is facing the passenger side of the engine bay. I searched and found boiler's thread on the replacement actuators...but are they really necessary to clock a t25? Also are any of you guys running your downpipes through the drivers side of the engine bay? One more thing, I have two different t25s, one is a generic brand but the other is a garrett tb25. anyone know what the 'b' is for and possibly what car it was used on?
Old Mar 10, 2008
Rufus's Avatar
Re: clocking a t25?
Mine runs down the driverside and I have a larger turbo.
Old Mar 10, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: clocking a t25?
the only thing i can think of that the B implies is ball bearing. by the driver side do you mean on the opposite side of the oil pan (away from where the stock downpipe goes under the oil pan?) mine follows the exact same way the stocker runs. if you are gonna run your downpipe through the driver side it might cost a bit more to get a downpipe (if you dont have one already) because when you get to extreme angles in bending shops tend to charge more because its harder to make it.
Old Mar 10, 2008
Re: clocking a t25?
i found that the tb25 is the turbo is off a sr20 (silvia motor)
Old Mar 10, 2008
Rufus's Avatar
Re: clocking a t25?
We made mine...
Old Mar 10, 2008
dust's Avatar
Re: clocking a t25?
the downpipe I have is made to exit through the drivers side of the engine bay. I have even thought about cutting the flanged top of the dp off and rewelding it on in the opposited direction...but then i would have to figure out how to clock the turbo so the inlet would be on the drivers side. I am just trying to not run into a lot problems when I start cutting my i/c piping. would any of you guys have pics of your downpipes?
Old Mar 10, 2008
dust's Avatar
Re: clocking a t25?
Old Mar 10, 2008
Rufus's Avatar
Re: clocking a t25?
Eh I could in a few days, car is at the shop
Old Mar 11, 2008
dust's Avatar
Re: clocking a t25?
okay just please post up when you get your car back
Old Mar 12, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: clocking a t25?
first question is what car is it that your working on?
here is a couple shots of mine...
Old Mar 13, 2008
dust's Avatar
Re: clocking a t25?
the turbo is going on an 05 lx but heres my problem the part of the turbo that the i/c piping starts at is facing up when i need it to face down.
ID:	73860   Click image for larger version
Old Mar 13, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: clocking a t25?
you need it to look like...
And may need a custom wastegate mount like i made
Old Mar 14, 2008
dust's Avatar
Re: clocking a t25?
so your saying i need to take the bracket thats holding the actuator off to clock it.....okay..... but when you clock a turbo only the exhaust part rotates?
Old Mar 14, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: clocking a t25?
the exhaust side is stationary, it bolt to the manifold so its forced to be in a certain position! Bolt manifold to head, bolt turbo to manifold then break bolts free on center section and remove wastegate. Then rotate intake side of turbo to desired position. And figure out whats needed for wastegate to attach to compressor. Also check this out it has lots of pictures that may help you....
http://myweb.cableone.net/tfnaaf/
Old Mar 15, 2008
dust's Avatar
Re: clocking a t25?
okay ive gotten that part figured out. another question tfnaaf: how did you run the intercooler piping from the turbo to the left side of the intercooler?
Old Mar 15, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: clocking a t25?
i removed the windshield washer bottle and ran it thru that hole. but if your car is EX it may not be as easy
Old Mar 15, 2008
dust's Avatar
Re: clocking a t25?
okay i will try that method. my car is an lx so no abs. the turbo i have has its wastegate flange bolted on so i think i can just loosen those and relocate them with no problems on sunday. I will post pics so you can see if i did everything right. BTW i have a buddy who is turboing a 94 gt mustang and my build is no where as complicated as his is. tnfaas u wouldnt have pics of your fabbed i/c piping before u installed it would u?
Old Mar 15, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: clocking a t25?
All the pictures i have are on that webiste. If needed i can try to take a picture that you may need thats not on there. Just let me know
Old Mar 16, 2008
dust's Avatar
Re: clocking a t25?
the specific pic i need is of the i/c piping from the turbo to the in-feed of the intercooler.
Old Mar 16, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: clocking a t25?
here is from bottom of turbo i used a 90 degree coupler. Then the piping. I trimmed the support of the fan a little but probably wasnt needed....
and here is coming thru to the intercooler......both pics are on my web page a long with many others
Old Mar 17, 2008
dust's Avatar
Re: clocking a t25?
okay man that is exactly what i needed to see. what demensions are your intercooler. The one i had was so big it fit on a mustang?
Old Mar 17, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: clocking a t25?
i dont recall its length, width, thickness
Marco83
Oct 13, 2018 10:13 PM
tropicola
Sep 25, 2015 07:02 PM
speedlever
Sep 24, 2015 07:18 PM
0396
Aug 21, 2015 05:27 PM
