clocking a t25?
clocking a t25?
Hey guys Im using a t25 turbo and I during a mock up installation I found out that i need to clock the turbo so the inlet is facing the passenger side of the engine bay. I searched and found boiler's thread on the replacement actuators...but are they really necessary to clock a t25? Also are any of you guys running your downpipes through the drivers side of the engine bay? One more thing, I have two different t25s, one is a generic brand but the other is a garrett tb25. anyone know what the 'b' is for and possibly what car it was used on?
Re: clocking a t25?
the only thing i can think of that the B implies is ball bearing. by the driver side do you mean on the opposite side of the oil pan (away from where the stock downpipe goes under the oil pan?) mine follows the exact same way the stocker runs. if you are gonna run your downpipe through the driver side it might cost a bit more to get a downpipe (if you dont have one already) because when you get to extreme angles in bending shops tend to charge more because its harder to make it.
Re: clocking a t25?
the downpipe I have is made to exit through the drivers side of the engine bay. I have even thought about cutting the flanged top of the dp off and rewelding it on in the opposited direction...but then i would have to figure out how to clock the turbo so the inlet would be on the drivers side. I am just trying to not run into a lot problems when I start cutting my i/c piping. would any of you guys have pics of your downpipes?
Re: clocking a t25?
Re: clocking a t25?
the turbo is going on an 05 lx but heres my problem the part of the turbo that the i/c piping starts at is facing up when i need it to face down.
Re: clocking a t25?
so your saying i need to take the bracket thats holding the actuator off to clock it.....okay..... but when you clock a turbo only the exhaust part rotates?
Re: clocking a t25?
the exhaust side is stationary, it bolt to the manifold so its forced to be in a certain position! Bolt manifold to head, bolt turbo to manifold then break bolts free on center section and remove wastegate. Then rotate intake side of turbo to desired position. And figure out whats needed for wastegate to attach to compressor. Also check this out it has lots of pictures that may help you....
http://myweb.cableone.net/tfnaaf/
Re: clocking a t25?
okay ive gotten that part figured out. another question tfnaaf: how did you run the intercooler piping from the turbo to the left side of the intercooler?
Re: clocking a t25?
i removed the windshield washer bottle and ran it thru that hole. but if your car is EX it may not be as easy
Re: clocking a t25?
okay i will try that method. my car is an lx so no abs. the turbo i have has its wastegate flange bolted on so i think i can just loosen those and relocate them with no problems on sunday. I will post pics so you can see if i did everything right. BTW i have a buddy who is turboing a 94 gt mustang and my build is no where as complicated as his is. tnfaas u wouldnt have pics of your fabbed i/c piping before u installed it would u?
Re: clocking a t25?
All the pictures i have are on that webiste. If needed i can try to take a picture that you may need thats not on there. Just let me know
Re: clocking a t25?
here is from bottom of turbo i used a 90 degree coupler. Then the piping. I trimmed the support of the fan a little but probably wasnt needed....
and here is coming thru to the intercooler......both pics are on my web page a long with many others
tropicola
Sep 25, 2015 07:02 PM
0396
Aug 21, 2015 05:27 PM
