Timing belt
Old Feb 19, 2008
flir's Avatar
flir is an unknown quantity at this point
Timing belt
My daughter owns a 2002 Civic with a little over 99000 miles. Should she have had the timing belt and water pump changed at this point? I'm not familiar with Hondas but this is what I've heard.
Old Feb 19, 2008
Re: Timing belt
yup 90k is actually a safer mileage (old schelude pre 01), even tho the updated schedule says to wait until 110k miles. i would have it done now because the engine could die if the belt snapped. water pump is also a good bet to replace since everything will already be taken off, and replacing it will be easy. so for parts, you just need the belt, water pump, and some coolant. maybe some cam seals if the ones on there cant be reused.
Old Feb 19, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
Re: Timing belt
I did mine at 105k and was fine, but yeah schedule it as soon as convenient, especially if you live in an extremely cold or warm climate - heat and cold cycles will shorten belt life.
Gratuitous plug: My DIY for the timing belt replacement.
Old Feb 19, 2008
WgnrNick's Avatar
WgnrNick will become famous soon enoughWgnrNick will become famous soon enough
Re: Timing belt
Yea, get it replaced. I'm going to be getting mine done at 95k.
Wagner
Old Feb 20, 2008
bbrian12's Avatar
bbrian12 is an unknown quantity at this point
Re: Timing belt
i got my 02 civic timing belt changed at 72,000 cause the belt was starting to slip
it cost me 600$ for the belt, water pump, accessory belts and labor
but that was at the dealer
im sure it can be done cheaper
Old Feb 20, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Re: Timing belt
I'm going to attempt it this spring with the gratious walkthrough above. Hopefully I can get it done without any major problems.
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
