removing foam sticker from wheels
Old Feb 14, 2008
okay i have alot of that adhesive foam stuff that held on previous wheel weights for balancing, now they are stuck there and i cant get it to come off without scraping at it for hours. googone didnt do anything... so idk, any suggestions?
Old Feb 14, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Re: removing foam sticker from wheels
There is this home remedy:
http://www.ehow.com/video_13445_remove-stickers.html
Or there are a bunch of other chemical removers that might work such as:
http://www.valsparglobal.com/val/resident/goof-off.jsp
Good luck!
Old Feb 14, 2008
hmm yeah something that wont damage the wheels lol. i should mention that its not just a small piece, its a total of about 12 inch of sticky stuff with foam on top. i guess i could try the alcohol that shouldnt ruin anything.
Old Feb 14, 2008
pheaton's Avatar
Do you a pic of the stuff you're trying to get off? What is the finish on your wheels? I guess maybe I'm thinking about something else. Foam adhesive?
Old Feb 14, 2008
you know the foam adhesive that is double sided sticky, well it sticks very well, but if you ever try and pull it off, the foam breaks before the adhesive does. so some of the foam sticks to the weight you pull off, but most is still stuck to the rim. rims are gloss black.
Old Feb 14, 2008
pheaton's Avatar
Next option:
WD-40 and a Hair Dryer.
Hit the area with WD-40 let it absorb for a few minutes. Get some heat on it and see if it will become plyable enough to remove. Use your fingernails and remember too much heat will mess with paint and make it easier to scratch so be careful.
WD-40 will not hurt paint, I promise.
A cold surface makes glue and crap hard to get off, so heat is important.
Old Feb 14, 2008
pheaton's Avatar
Oh look, here is a guy using the same technique on his motorcycle to get a sticker off of the fuel tank.
http://www.motorcyclecruiser.com/tec...int/index.html
Hope it works, sounds like you're dealing with some real crap there.
Old Feb 14, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Take a wet rag, with warm water and soak it good. Let the rag sit on the foam for a while, 10-15 minutes to get it saturated. Then you should be able to scrape it off easily.
Old Feb 14, 2008
maybe ill wait for summer lol
Old Feb 14, 2008
burke420's Avatar
The World Is Yours!
goto a local parts supplier of 3M and get an adhesive remover from them... its called 3m adhesive remover! i use it at my job...Discount tire and it's wonders... it's like $12 a can!
Old Feb 14, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
^I have some of that stuff in my frame shop its great it's also usually relabeled as paint thinner, or mineral spirits which will take off most adhesives in a couple of sec when applied with a towel or rag
Old Feb 14, 2008
burke420's Avatar
The World Is Yours!
thats why its prolly $12 retail.... so try it gearbox and you know what to do! b/c itlll work once the fluid is soaked into the adhesive.... itll Bounty away!
Old Feb 15, 2008
nice ill search around for that
Old Feb 15, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
sweet info here!!!
Old Feb 15, 2008
burke420's Avatar
The World Is Yours!
you betcha... i promise itlll work.. unless you got some painty areas on it too! but it's pretty durable and strong stuff...and just dont let it get into flames... it fun stuff and i accidentally blew up my old can...lol
Old Feb 15, 2008
pheaton's Avatar
Gearbox your wheels are painted though right? You don't want something that is relabled paint thinner do you?
Old Feb 15, 2008
i need to read the ingredients yea. if theres anything like there is in paint thinner/laquer thinner, i wont get it. like no acetone, etc.
Old Feb 15, 2008
djmota's Avatar
Just find somebody with a heat gun, borrow it. Get things nice and hot and scrape. it will come off nice and easy.
Old Feb 15, 2008
pheaton's Avatar
I'm thinking heat is a definate necessity. And like I said WD-40 might help things along.
Old Feb 15, 2008
okay thanks. i have heat gun but no way to plug it in.. ill wait til summer then
Old Feb 15, 2008
burke420's Avatar
The World Is Yours!
im telling you gearbox... we always use it and just dab it on the paper towel(bounty) and wipe away...dont try and splash it on there!
Old Feb 15, 2008
okay well if it strips the rims you can buy me new ones
Old Feb 15, 2008
burke420's Avatar
The World Is Yours!
what are the sticker weights on the spokes... comeon... use lightly on a paper towel or rag...and rub till gone! when ive used it... ive never removed the paint from the wheels
Old Feb 16, 2008
okay will give it a try. i need to check a few more places.
Old Feb 16, 2008
great +1 to you, 3m stuff stripped the whole foam and sticker right off lol. took about 10 mins for all four rims then i got sad when i saw all the screwdriver chips and scratches from the shop trying to pry the weights off
Old Feb 17, 2008
Da1lyDr1ver's Avatar
where did you end up findning the 3M remover? i need some of that for the same reason as you.
Old Feb 17, 2008
farm and fleet, in the glue/epoxy section. i think a hardware store may have it in the paint section with all the other containers of acetone and stuff.
Old Feb 18, 2008
02BLKCIVIC's Avatar
coooool
GolNat
Suspension DIY
May 12, 2022 06:49 AM
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Dreamer01
Detailing
Dec 22, 2001 10:17 AM
02Si
Dec 9, 2001 07:37 PM
