engine putts and sputters when a load is applied
Old Jan 13, 2008
Turbocivic96's Avatar
Turbocivic96 is an unknown quantity at this point
My honda civic had a b18b1 dohc integra engine in it with a t25 greddy turbo kit. i recently took my car to a dyno to help figure out what the problem was. It all turns out that when a load is applied (2nd,3rd,4th,5th gear) it putts and sputters around 3-4 rpm. I then took the tube off the intake and ran it straight open no turbo, it did the same thing so it rules out the turbo. Note that the car runs lean all the time. any idea? maybe a sensor issue or computer problem??
Old Jan 13, 2008
varner88's Avatar
...JeRsEy sTyLe...
varner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of light
Re: engine putts and sputters when a load is applied
change your plugs??? turbo cars eat them up
Old Jan 13, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
Check the plug gap and change the plugs. You may also want to run through the fuel system, the pump, the regulator, the injectors, and so on.... Running lean is never a good thing.
Old Jan 13, 2008
lemac's Avatar
lemac will become famous soon enough
^+1... I would also check the tps, just to rule that out plus its quick and easy.
Old Jan 25, 2008
Devin Eaton's Avatar
Devin Eaton is an unknown quantity at this point
well check and see if your fuel pressure regulator is adjustable or if its closed try new plugs too its probably not getting fuel fast enough in high rpms if its running lean all the time.
Old Mar 26, 2008
lownslow96's Avatar
lownslow96 is an unknown quantity at this point
this may help, my car was doing the same thing, and i changed a fuse, the alternator/s sensor fuse and it stopped, i had no speedo and it ran like crap, if i kept the gas pedal barely pressed it ran fine, but as soon as any kind of pedal was given it spit and sputtered
MyCivic
Electrical
Oct 28, 2021 11:06 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Ninetyatecivic
May 9, 2015 07:48 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
