cv joint or not?
Old Dec 31, 2007
dlssboyce1's Avatar
dlssboyce1 is an unknown quantity at this point
Question cv joint or not?
i have a 2003 civic ex,it just started making a clicking noise when you turn to the right at slow speed,so i checked the boots on both axles and they are good.also forgot to mention it doesn,t do it all the time.the car has 80,000 miles on it and the suspension is stock,anybody got any ideas
Old Dec 31, 2007
lemac's Avatar
lemac will become famous soon enough
Re: cv joint or not?
did you check both inner and outer boots? usually slung grease around the area are good indicators of worn or torn boots.
Old Jan 1, 2008
dlssboyce1's Avatar
yes l checked the boots on both axles,no grease.i did some checking and found out there was a tsb bulletin from honda on this problem,the reverse idler gear is making contact with the1st/2nd hub sleeve in the trans.so i guess i will go argue with the dealer to get it fixed.thanks for the help
jackoncruzpr
Sep 29, 2015 07:59 PM
Joecrowe
Sep 24, 2015 09:12 AM
bashea
Sep 15, 2015 04:59 AM
EdGasket
Aug 29, 2015 09:58 AM
califcamper
Jul 21, 2015 10:34 PM
