8th Gen Factory subwoofer Replacement
Old Dec 18, 2007
07exNavi's Avatar
07exNavi is an unknown quantity at this point
Does anyone know whether or not you can drop in an aftermarket 8 inch sub into the back deck, replaceing the one that came from the factory? I wouldnt want to replace any of the wiring or change anything except the speaker. Im thinking of the 8 inch sub from MTX but im just throwing around ideas.
Old Dec 18, 2007
ES2Guy's Avatar
StAyInG StOcK aNd MarRiEd
ES2Guy is an unknown quantity at this point
Re: 8th Gen Factory subwoofer Replacement
There shouldn't be any reason why it won't fit, just make sure that the depth isn't a factor. Pull the old speaker out and measure. That is all.
Old Dec 18, 2007
jrock's Avatar
jrock will become famous soon enoughjrock will become famous soon enough
there could be an issue with the amount of watts going to the sub....aftermarket subs will prob need more rms
Old Dec 18, 2007
ricanswt's Avatar
ricanswt is on a distinguished road
Correct me if i am wrong, but from what i can tell, the factory kit is two 6.5" subwoofers, not a single 8". That being said, the subwoofers pictured by honda appear to be of Free-air design (a subwoofer that does not require an enclosure). I personally do not know of any 6.5" free-air subwoofers from aftermarket companies. I will search though.
Old Dec 18, 2007
choughster's Avatar
choughster is an unknown quantity at this point
on the 8th gen SI & i think EX(not sure?) they have an 8inch sub between the rear speakers, i wish the 7th gens have the same setup
Old Dec 18, 2007
ricanswt's Avatar
Found a 6.5", free-air capable, subwoofer from a company called Elemental Designs. I never heard of this company, so be cautious.
Take a look here: 7Kv.2 Subwoofer
Old Dec 19, 2007
CivicFreak03's Avatar
CivicFreak03 has a spectacular aura aboutCivicFreak03 has a spectacular aura about
Regardless if its 8'' or not you going to run into problems. Most factory subwoofers have a odd ohm reading that no aftermarket will match. If you replace with a 2 or 4 ohm sub you will either a) fry the new sub or b) fry the factory amp (most likely what will happen). I would advise just disconnecting the factory sub and add your own set of amp(s) and subwoofer(s) <---- Not as clean but you will run into less problems that way.
Old Dec 19, 2007
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
not many aftermarket subs are free-air also.
Old Dec 21, 2007
07exNavi's Avatar
I was worried about it being a free air sub, what an odd design. I think ill just leave it alone, thanks for the input. I could throw the tens that I had in my truck in there but I want to keep the trunk space. I was lookin for a nice compromise but I guess stock is good enough. Less ear damage that way, ha ha.
Old Dec 23, 2007
D-Vus CIV's Avatar
my civic gets me pu**y.does yours???
D-Vus CIV can only hope to improve
elemental designs is a good compan. they make good subs for the money.lots of spl cars run their stuff.and i thought that the rear sub had a plastic tub enclosure.if so then a simple swap would do.most subs run at 2 or 4 ohm but ive seen 8 ohm too.stock and aftermarket stereos run 4 to 8 ohms so if you just find the info on ohmage and then wire them correctly then yeah it will work.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
WLakers
May 4, 2015 06:23 PM
thesushiboy
Apr 12, 2015 02:54 AM
djaber
Jan 4, 2002 06:23 PM
