lx header o2 defouler or 02 simulator
Old Nov 25, 2007
turbopseidon's Avatar
turbopseidon is an unknown quantity at this point
i have been reading alot on the the o2 defouler and wondering if anyone is using one of these to trick the ecu into not throwing codes OR do yous use an 02 simulator? thanxs
Old Nov 25, 2007
greeen01civic4d's Avatar
Re: lx header o2 defouler or 02 simulator
yes, i have an lx header(kamikaze) and defoulder(bent) works for me
Old Nov 25, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
The non fouler works Ive tryed it a few times. Wish I knew that 2 years ago, lol.
Go to your local auto store, get 2 spark plug non foulers. Drill one out and thread it on the second o2 sensor, basically its just a spacer, then thread the other non-drilled one onto the other one and screw it into the bung. My best friends AP1 with no CAT has never once thrown an 02 code, EVER! it works awesome with no ill effects whatsoever.
Old Nov 25, 2007
yep, same here
Old Nov 25, 2007
will the 2 o2 foulers with the header hit on anything like the altinator?
Old Nov 26, 2007
tfnaaf's Avatar
BLDNPSI Mod
follow the link in my sig for a diy on the foulers
Old Nov 26, 2007
what header did u get??? if its kamikaze, then probably hit the block, mine did, i got a bent one from a member here, if u want to find him hit me up, ill see if i still have his screenname saved
Old Dec 29, 2007
Datsrboi's Avatar
Datsrboi is an unknown quantity at this point
Never had to do this before. But can someone confirm that they have always passed state inspection with this? My friend has an 02 civic and did that on his car. No CEL nor anything. But when we were at the state inspection and they guy plugged it up to the machine, It failed his car even with no CEL of any kind.
Old Dec 30, 2007
speedfoos's Avatar
Well of course it will fail an emissions test. The car is still shitting out noxious, un-catalyzed (not burnt up) exhaust. It's just that the ECU doesn't think so anymore.
Old Dec 30, 2007
tfnaaf's Avatar
BLDNPSI Mod
My car passes emissions test EVERY year with the de-fouler. But your state test may be different. What part of the test did they say that he failed? In my state they test for as i recall 8 things and you can fail 3 of the 8. my last 2 years i didn't fail any parts of the test. But all they do is obd2 scan and thats it! No visual or tail-pipe sniff at all.
TRIZ
Bolt-on Engine Performance
Jan 19, 2022 09:42 PM
zps2004
Jul 18, 2008 07:21 PM
+MM+
May 27, 2008 11:11 AM
mig
May 6, 2004 11:35 PM
Shlomo
Apr 30, 2004 05:14 PM
