B16a2 Problems!!need Help
Old Nov 18, 2007
305civicsiowner's Avatar
305civicsiowner is an unknown quantity at this point
Question B16a2 Problems!!need Help
i have an 2000 civic si...it has AEM short ram,DC Sport 4-2-1,apexi n1 catback,an its tuned on hondata s300.....an my car was running good an now it is denating an now n 1st gear the vtec is SUPPOSED to cross over at 5k rpms an sometimes it doesnt kick on till 5800 rpms or it dont even kick on...an in the rest of the gears its not pulling as hard as it did before...if you have any idea please help....i talked to a few people an no one has any idea...thanks
Old Nov 18, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Re: B16a2 Problems!!need Help
Check your oil level
Old Nov 19, 2007
TRIZ's Avatar
Please dont tripple post. Your other two threads have been deleted. Thanks.
Old Nov 19, 2007
DsevenEm2's Avatar
This is Myspace
who tuned your hondata... your best bet wouldnt be asking people on a forum, you should head back to whoever tuned your ecu and they should be able to see all of the problems..
Old Nov 19, 2007
familycar's Avatar
check your plugs as well, you may have been running alittle rich or have an inconsistant fuel pressure causing detonation
Old Nov 19, 2007
TemjinX2's Avatar
check this first. if the motor doesn't have enough oil, the car will go into limp mode and not go into vtec.
if not, its probably bad tuning.
mrcell24
May 19, 2015 10:02 AM
sysblack
May 13, 2015 08:55 PM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
