wiring problems
Old Nov 7, 2007
wontonamo's Avatar
wontonamo is an unknown quantity at this point
wiring problems
my horn doesn't sound anymore and when i do press it, it blows the fuse for the horn and stop light. what could be the problem? and how can i fix it? as a temp solution, i disconnected the horn and it seemed to stop blowing fuses. how can i fix it to where my horn will sound and it wont blow a fuse?
thanks in advance
Old Nov 8, 2007
wontonamo's Avatar
Re: wiring problems
bump! i need help
Old Nov 8, 2007
CraigW's Avatar
Re: wiring problems
At what point did you un-hook the horn ?? If you unhooked the actual horn itself, and the fuse is not blowing now (assuming you have pushed the horn button on the steering wheel since un-hooked) that may indicate the horn itself is the problem.
4 banger
Jun 5, 2015 01:44 AM
dinsum
May 28, 2015 09:30 PM
pincookie1
May 4, 2015 12:22 PM
Dmitri
123
Oct 13, 2005 08:01 PM
blackbullet
Dec 1, 2001 03:44 PM
