grinding noise from clutch
Old Oct 29, 2007
red05's Avatar
red05 is an unknown quantity at this point
I have a 2005 civic manual. When I press in the clutch to change gears, I hear a very slight metallic grinding noise. I can only hear it when I have the windows down. Is this just the normal noise of the clutch releasing? Or could this be something different. I haven't noticed the noise until recently. The car only has 29,000 miles on it. Thanks.
Old Oct 29, 2007
EMTwannabe's Avatar
EMTwannabe is an unknown quantity at this point
Re: grinding noise from clutch
Is it in all gears? It's not normal (except maybe a little bit in reverse) I would start with a fluid change.
Old Oct 30, 2007
andyman97's Avatar
Turbo Guru
You're clutch doesn't grind. Your clutch is made from an "organic" material, not metal. It sounds like your syncros to me. You may need to have them replaced, machined or pick up a new tranny.
Old Oct 30, 2007
red05's Avatar
Thanks. I will take it to the dealer to have it looked at since it is still under warranty.
mokkush
Jul 14, 2015 04:05 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
1khilari
Jul 9, 2015 08:12 PM
