Engine shakes at 3500 rpm range
Old Oct 29, 2007
mcwhorbm's Avatar
mcwhorbm is an unknown quantity at this point
Okay, I have searched on the internet and couldn't find much. Hoping someone out there has a suggestion before I take it to a garage.
I have a 2001 Civic with a manual transmission. The check engine light is on. No matter what gear I am in, if the RPM hits about 3500, the engine begins to shake and the rpms begin to drop. The shaking will stop if I upshift or drop the rpms back below 3500. The car runs fine at the lower rpms.
Not a big problem yet but I can't do much over 80 on the interstate.
Any ideas?
Thanks,
Brian
If you think this belongs in another forum my apologies. Please just let me know where to post it.
Old Oct 29, 2007
Re: Engine shakes at 3500 rpm range
um, how about you get the code figured out. it will probably tell you whats wrong. its free at most auto parts stores. otherwise nobody is gonna sit here and guess the problem.
Old Oct 29, 2007
drew22mader's Avatar
There is gl@ss in my @SS...
Almost sounds like your car is in Limp Mode. But like Gearbox has stated, no one knows unless you take it and get the code, it's free.
Old Oct 29, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
a few things ive experienced in my life on engine shake @ X RPM
Balance shaft.
Timing (one car the oil pump had to be timed aswell) this caused shake.
just a few guesses....
Old Oct 29, 2007
kasimmmmm's Avatar
uhhh.... i'd also check the motor mounts. The bushing can be warn out.
Old Oct 29, 2007
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
could be the spark plugs or a high side of the cylinders misfiring...
Old Oct 30, 2007
gmag21's Avatar
gmag21 will become famous soon enoughgmag21 will become famous soon enough
i had a similar problem and i BLEW MY ENGINE... no not turbo'd it i mean ruined it... i was having the same problem, my rpms were all f'ed up with the engine shaking and i didnt know what to do... i was on the highway cruise controlling 70 and all of a sudden it started slowing down, smoking, shaking and then turned off! looooooooooong *** story that im not getting into but you need to take it to a shop asap and tell them it might be the load detection module, thats what was wrong with mine, i had to get a new engine and everything.
Old Oct 30, 2007
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
Same ish happen to me, but iwas doing more like 80 and when I tried to slow down it was too late.
Old Oct 30, 2007
gmag21's Avatar
its bullshit... i wanted to put a k20 in it after that but i didnt have enuf $ and my rents wudnt pay for it
thana
Jun 15, 2020 07:05 PM
Wild Cranker
May 19, 2015 06:10 PM
lildoo
May 9, 2015 09:44 AM
bobbyd
Bolt-on Engine Performance
16
Dec 14, 2001 01:39 PM
Hobby2K
Nov 9, 2001 04:08 PM
