8th Gen 2006 - 2011.
2007 honda civic sedan road noice
Old Oct 3, 2007
rick93684's Avatar
rick93684 is an unknown quantity at this point
is it just me but are all 2007 honda civics sedan all have road noice? on highway gets worst and louder on every bump
Old Oct 3, 2007
arbittan's Avatar
arbittan will become famous soon enough
Re: 2007 honda civic sedan road noice
The 2007 Civic does suffer from road noise, but I can say it is a lot better now than what was in 1990 and 1994.
If you adjust your radio to a comfortable level, it will drown out the road noise. You can also try installing noise damping material. Lining your trunk floor and lid, your doors, floor boards will cut down a lot of the noise you hear. It will not eliminate all the noise.
Old Oct 3, 2007
BTRobertson's Avatar
BTRobertson is an unknown quantity at this point
Plus, adding the damping material will add weight to the car. I got used to it very quickly and use the radio to drown anything out anyway. To be honest, the exhaust gets more annoying to me on long trips than road noise. I think the 2007 Si Sedan is a very solid-sounding car on the highway. It also depends on the tires and the condition of the road. Damping material adds a lot of weight to cars; people don't realize that.
Old Oct 3, 2007
rick93684's Avatar
and were do i get that stuff and how do i install it
Old Oct 3, 2007
KenB's Avatar
KenB is an unknown quantity at this point
+1 - just got back from a 500 mile drive to visit my daughter. The exhaust does get to you after a couple hours but the road noise is minimal. My '07 Si Sedan was traded in for a Lexus ES 300 and, aside from the exhaust note, I really don't notice more noise from the Si. Very acceptable IMO.
Old Oct 4, 2007
11sec70dodge's Avatar
11sec70dodge is an unknown quantity at this point
dynamat, bestbuy/ EBAY buy it in bulk, big roll for 150$ well worth the money remove the door panels and stick it to the door and under your carpet
Old Oct 4, 2007
rick93684's Avatar
bestbuy? how can a sticky thing stop road noice? and does it make the car heavy
Old Oct 4, 2007
arbittan's Avatar
The material will absorb the sound vibrating through the metal. Mostly what you are hearing is resonation from the actual noise.
Old Oct 4, 2007
MarchMadnessisM's Avatar
MarchMadnessisM has a spectacular aura aboutMarchMadnessisM has a spectacular aura aboutMarchMadnessisM has a spectacular aura about
its a big heavy foam pad, its like puttin a blanket over a speaker u still hear it but not as loud, its the same stuff ppl use 2 stop rattleing when thet get subs
Old Oct 4, 2007
rick93684's Avatar
but wont i see it when i install it in my trunk
Old Oct 4, 2007
arbittan's Avatar
No, the only places you will see it is on your trunk lid. The other parts you cover with it will be hidden by carpet and siding trim.
Old Oct 4, 2007
not foam but an asphalt based material
Old Oct 5, 2007
rick93684's Avatar
and whats it called so when i go to bestbuy i know what to look for
Old Oct 5, 2007
arbittan's Avatar
Goto crutchfield.com and lookup sound damping.
Old Oct 10, 2007
wincros's Avatar
wincros is an unknown quantity at this point
Road noise is mentioned in almost every review. That said it is much less on my coupe than the Subaru I had. The worsening you hear is probably the tires breaking in. I have noticed it already on my Civic. Bridgestones are very noisy. I replaced the Bridgestones on my WRX with Pirellis and got a better ride, lots quieter ride and better handling. I may do that with the Civic too.
Old Nov 11, 2007
lahealth's Avatar
lahealth is an unknown quantity at this point
Take YOUR CAR TO A TIRE SHOP AND CHECK THE REAR TIRES,I HAD THE SAME PROBLEM .......AND TIRES WERE THE PROBLEM.
Old Nov 12, 2007
Argo's Avatar
Argo is an unknown quantity at this point
I might suggest checking the tires as well. I recently put winter tires on and wow, are they noisy compared the all seasons it came with. It's something I'll just have to put up with until spring.
In general (pre winter tire installation), I don't find my sedan noisy. It's completely silent compared to my previous car that I had for 17 years!
Old Nov 21, 2007
wincros's Avatar
I just rode in a friend's late model Corolla and it's ride was way harsher and noisier than my 07 Civic EX coupe. I know "reviewers" like to talk about Honda road noise, but I think it is a crock myself.
Bridgestone tires are notoriously noisy and mine are still new. I imagine I will be looking for some quieter tires by my second or third service.
Old Nov 21, 2007
getting quieter tires will make THE MOST difference in amount of road noise. switching from the firestones to some quality bridgestone turanzas (same as on the acura TL) made my 02 civic go from geo metro to lexus quiet. sounded like a totally different car. next time you need to buy tires, goto tirerack.com and read the reviews, paying attention to road noise factor.
vtec92
May 4, 2017 03:20 AM
jessicakaybby
Apr 20, 2015 12:11 PM
aus10
Apr 13, 2015 09:26 PM
gabrown2
Apr 11, 2015 08:22 PM
Lightman
Nov 10, 2001 06:44 PM
