Can't slam our car!!!!!
Old Mar 29, 2002
Essa's Avatar
Essa is an unknown quantity at this point
What you guys think of this[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Let me list the problems you're going to have:
1. You have to roll up you rear fender lips [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
2. You have to find a really short shocks for your rear suspension
3. You start bottoming your front shocks (no matter if you have koni install)
4. Speed Bump is absolutely a bitch
5. Both of your rear camber arms start hitting the chassis This is the real problem. There's nothing else you could do unless you want to cut your chassis to accomodate travel distance for your camber arm and I'm not going to do that. No matter what kind of suspension you have, bags or pneumatic or hydrolic, as long as you still have that camber arms, you're going to have the same problem.
I thinking to raise it again about 1" (to its previous height) . I can live with that.
Therefore for all the people out there, be really careful if you want to slam your car.
The 7th generation civic has a suspension limitation compare to previous generation.
BTW, take a wild guess, how low did I lower the car [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 29, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Cars looks great !!!
As far as how low....too low for me! I couldn't even get out of my driveway with that drop.
Old Mar 29, 2002
speedracersong's Avatar
yeah nice job essa
i want to drop mine pretty soon too.
have fun scraping the asphalt[IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 29, 2002
Essa's Avatar
speedracersong, the asphalt isn't a problem....[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
The problem is the rear camber arm hitting the frame of the car when you make a sharp cornering. Therefore, tomorrow I decided to raise my car 1". Too bad though....I like the way it looks now.
Old Mar 29, 2002
fraga's Avatar
Wicked Moderatuh
My God Essa, just be vewy vewy careful. Stay clear of rocks, pebbles, and ants. Looks great though.
Old Mar 29, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
<< speedracersong, the asphalt isn't a problem....[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
I love the way it looks too, but it's too big of a sacrafice for the quality of out cars... gotta considerate to it's overall drivability.
Old Mar 29, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
u run into the same problems with other cars....not just ours
Old Mar 29, 2002
SoNiCcIvIc's Avatar
If you put an exhaust on your car at that height, it'll scrape ar every dip, too.
But it looks good! Drop it that low at a car show.
Old Mar 29, 2002
SoNiCcIvIc's Avatar
<< My God Essa, just be vewy vewy careful. Stay clear of rocks, pebbles, and ants. Looks great though. >>
LoL, ants... WTF? [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 29, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
when i had GC... i slammed it... it was cool and all.. but i couldnt stand the ride. it was unbearable! now i am on springs... and they ride like stock!
Old Mar 30, 2002
SilverCivic2K1's Avatar
SilverCivic2K1 is an unknown quantity at this point
<< &lt;&lt; My God Essa, just be vewy vewy careful. Stay clear of rocks, pebbles, and ants. Looks great though. &gt;&gt; >>
hahaha...ants!!..termites too!
Welll...I want to get air bags and raise the height when I'm driving..and then when I am parked, drop it to the GROUND!! hah
Old Mar 30, 2002
Grey's Avatar
DIY King
Thanks for sharing. The fender lips look ugly anyway, so I might roll mine out of the way somewhat. Actually, I already did a little bit, but I want to do it a little more. Anyway, I'm planning on getting air struts / air bags for my ride. I'll lower it to a reasonable height, but I'll adjust it so that the lowest height isn't too low and the highest height is almost stock, but a little lower than stock. Something like that. Well, unless I can control it to whatever height I want. Then I guess I would go as low and as high as possible. Thanks for the warning though. I'm at stock height and I have grinded up against stuff before because of my front end.
Old Mar 30, 2002
Essa's Avatar
Guys, actually the ride isn't that bad since I'm using Carrera small body shocks for rear, koni for front. Anyway, I'll raise my car soon....I can't bear hearing my rear camber arm hitting the frame.
Old Mar 30, 2002
TOOLOWCIVIC's Avatar
Where did you buy the rear shock and how much Are the rear shocks better than having Konis on the back. I have my car lowere about 1.5 with Ground Control and Konis. It still bounce a lot in the rear[IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Mar 30, 2002
Phatster's Avatar
Phatster is an unknown quantity at this point
My Civic Lx is dropped 2 inches all the way around and it is low, My exhaust does scrape coming out of certain driveways and on dips and such, I would not recommend dropping it that low because it can become a very bumpy ride. I think your car could go lower than that man cause my car is that low without a body kit.
Old Mar 30, 2002
zappa's Avatar
zappa is an unknown quantity at this point
D@mn, it looks real good I'm putting on coilovers this weekend , I dont think mine will be slammed like that though. Its to bad we cant drive around like that, It looks so good.
Old Mar 30, 2002
Essa's Avatar
<< Where did you buy the rear shock and how much Are the rear shocks better than having Konis on the back. I have my car lowere about 1.5 with Ground Control and Konis. It still bounce a lot in the rear[IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG] >>
TOOLOWCIVIC, you can buy the rear shocks from Carrera direct or www.Speedwaymotors.com. The shocks are adjustable and come in many different stiffness either for rebound and compression. Beside that, you have to buy the 1.75" dia. carrera coilover kit, since GC and any other Coilover kit comes with 2" dia. sleeve. I can tell you in more detail if you're interested.
The reason I'm using Carrera, it's because I wanted to drop it more than 3".
The ride is pretty nice...not bouncy.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 30, 2002
Confinement's Avatar
Confinement is an unknown quantity at this point
wow! thats pretty low, there is always a way to get it lower, BAGS! haha that solves everything for me! anyway, have fun i have my car a little higher than that and i drag like heck! oh well small prices to pay for looking good!
Old Mar 31, 2002
WhiteRabbit's Avatar
essa, who did your paintjob, and how much? looks nice.......
Old Mar 31, 2002
Essa, email me at toolowcivic@yahoo.com and give me more information on the rear shocks.[IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 31, 2002
01EXtc's Avatar
01EXtc is an unknown quantity at this point
Essa!
I work for a company called Air Ride Technologies and we will be developing a kit for our cars very shortly. Once it is completed I can give you a cost on it and if you are interested I might be able to give you reasonable discount so I can get a few kits out. Serious people only though, by the looks of your car I know you are.
Lucas NormanAir Ride Technologies
Old Mar 31, 2002
01EXtc, will you email me at toolowcivic@yahoo.com when you get a chance about the price of the air suspension. I would really like that. Does it ride as smooth as everybody says it is[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 31, 2002
Essa, I've checked the websites but I can't find the shocks for our cars[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 1, 2002
Essa's Avatar
TOOLOWCIVIC, Look for
1. Chrome small body shock #3265.
2. Coilover kit #1951
3. Stud conversion
You still have to use your previous coilover spring or you need to buy a 2.5" dia. spring.
Hope this help[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Apr 1, 2002
Essa's Avatar
<< Essa, email me at toolowcivic@yahoo.com and give me more information on the rear shocks.[IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG] >>
WhiteRabbit, it isn't a paint job. It's a decal (sticker). I can peel it off when I get bored. I design the decal and have a shop in LA to print it. The shop is located on San Gabriel/Del Mar in LA[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
Richkid23
Apr 19, 2015 12:53 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
crazydragon
Nov 2, 2001 10:59 AM
