sqeaky clutch pedal !!!!
Old Sep 1, 2007
valenzuela's Avatar
valenzuela should not be trustedvalenzuela should not be trustedvalenzuela should not be trusted
Exclamation sqeaky clutch pedal !!!!
Okay I have tried universal grease ,I've tried Lithium grease, and still sqeaks i am starting to run out of ideas here i took it to the honda dealership once for them to do it it worked for about a month than started again . i know for sure its the clutch pedal assembly NOT the clutch master cylinder.
If anyone has a quick fix for this problem, could you let me know a.s.a.p.
Old Sep 1, 2007
greeen01civic4d's Avatar
Re: sqeaky clutch pedal !!!!
honestly i used motorcycle chain oil, just make sure u get it in there good, if that doesnt work, try penetrating oil(pb blaster)
Old Sep 1, 2007
lordhelmet's Avatar
search... there are sqeaks associated with a bunch of things dealing with the clutch.
Old Sep 1, 2007
TRIZ's Avatar
Follow the pedal assembly through the fire wall.. shoot it with white lithium greese from both sides, and really get it in there. Then find the double boot and spray the heck outta the inner boot too. No more squeeks.
Old Sep 1, 2007
triz to the rescue!!!! hes like a super mod or something
Old Sep 1, 2007
valenzuela's Avatar
yea i have already loaded lithium grease on the slave cylinder and the release fork and no more sqeaks coming from there it the damn pedal ill try the PB blaster that always comes in handy.
Old Sep 6, 2007
jakes01civic's Avatar
jakes01civic will become famous soon enough
i had the same problem a few months ago. i just sprayed WD-40 on the assembly and it stopped, and it hasn't done it since.
Old Sep 6, 2007
TRIZ's Avatar
haha, thats now quotted!
Old Sep 6, 2007
haha, im famous now, thanks triz
Old Sep 6, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
WD40 all the way ... u will need to do it again after 4 months though !!!
Keep in mind when ur spraying the WD40 with your other hand keeping pressing and releasing the clutch at the same time and ull notice all the squeaks go away ...
Scout1
Oct 5, 2015 01:33 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Klame9420
Sep 7, 2015 10:03 PM
violentpanda
Sep 7, 2015 11:49 AM
tommycanada
Sep 5, 2015 04:59 PM
