Please help, car won't start after starter motor was replaced
Old Aug 23, 2007
sem40138's Avatar
sem40138 is an unknown quantity at this point
Unhappy Please help, car won't start after starter motor was replaced
The starter motor burned up the other day while trying to crank the motor and even after i replaced it with a new one it doesn't go unless i hotwire directly from the battery to the ignition terminal. I've checked all fuses under the driverside dash and passengerside underhood, and i can't find anything blown. I don't know what to do, it was just working the other day!!!
Old Aug 23, 2007
Alpha 5's Avatar
Re: Please help, car won't start after starter motor was replaced
Try swapping the relays around. You might have burnt one up.
Old Aug 23, 2007
ya if the starter works with direct connection, somethings wrong with the wire system leading to the ignition.
Old Aug 23, 2007
chinaman's Avatar
chinaman is an unknown quantity at this point
Have you checked your ignition switch? Use a test light to see if you have signal to the starter from the ignition switch.
Old Aug 24, 2007
sem40138's Avatar
Would the ignition switch go out if the starter motor went out? Also, i'm not sure with relays have to do with the starting circuit.
Old Aug 24, 2007
Alpha 5's Avatar
The ignition switch could go out, the wires in the switch are small, you could also have carbon build up on the contacts. The carbon would be the result of excessive current. It is unlikely but possible.
With regards to the relays. When you turn the key the starter wire does not run from the key to the starter. It runs to a relay. This goes back to the wires in the switch being too small for the current.
CivicVoz
Apr 16, 2015 08:07 PM
SSMatey
Apr 13, 2015 06:09 PM
thesushiboy
Apr 12, 2015 02:54 AM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
