Squeaking/hissing/whinning noise coming from engine.
I just had a sound system put in my 03 Civic SI Coupe. Ever since, there has been a strange whistling noise for the first 5 minuites I drive my car, what is this?
Re: Squeaking/hissing/whinning noise coming from engine.
Actually, timing belts don't whistle. Its auto tensioned. Maybe you should spend a little more time reading than doling out advice when you have no idea what you're talking about.
The whistling is probably from road noise. Check out the ICE section for causes and fixes.
Then you didn't have it all the way on... I live in DC and I lived in Louisiana, two extremely humid places and have never had a new timing belt squeal. Installing a new stereo system is not going to cause the timing belt to squeal either....
Back to topic
Does the noise get louder as you accelerate or is it just a constant tone?
Could it possibly be coming from your front speakers and you just think it is the engine?
Did you have the stereo professionally installed? If so where?
Back to topic
Its a DISCUSSION FORUM!!!! Debating and discussing about MECHANICAL PROBLEMS is the whole point of this forum.
And you aren't a moderator or administrator, so don't think you're going to tell anyone what to do and they're going to listen.
I think I found it. If you have a capacitor for your system. What it is than is the capacitor charging up. But thats only from 1.3 farads and lower
Calm down ladies. Alpha is on the right track. It's most likely coming from your speakers. i can't remember the whole explanation but it has to do with electrical interference. This is why you have to run your power cable and RCA cables on opposite sides of the car, as far away from each other as possible.
And why are you arguing anyway?? This thread is from August 6th and the original poster hasn't updated since.
civicns
May 8, 2015 09:49 PM
