How do I remove spark plug seals?
Old Jul 17, 2007
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
I'm replacing them with new ones, but they won't budge, and I'm scared of damaging the aluminum.
Old Jul 17, 2007
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
Re: How do I remove spark plug seals?
If you're trying to get the spark plug out you need to use a spark plug socket and extension. Then a gap tool and torque wrench to put it back on
Old Jul 17, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
^read the title of thread. Come on, seriously.
Get a small pick, a pair of needle nose pliers with grippy jaws, and a small flathead screw driver. Just work your way around the outside of the seal and work em loose. Grab em with the pilers and pull. Eventually they'll come out, but they suck. Plan on trashing the old ones, but you shouldnt bother the valve cover at all. I think I may have even tapped the screw driver around with a hammer.... aluminum isnt that fragile
Old Jul 18, 2007
speedfoos's Avatar
^^^ Exactly. I initially tried just pulling them out with a pair of needle nose and they just ripped. Then I just used a flathead screwdriver and popped them out, easy as pie. With the VC off that is.
Old Jul 18, 2007
I ended up tearing a 1 1/2 piece off one of the old drive belts and used it for leverage for the flathead. Made sure the flathead was as thin at the end as possible, and slipped it right under the seals. They are in there tight but not too tight.
Thanks for the help.
Old Jul 18, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
yea theyre a bitch to get out... screwdriver and hammer
159
Jul 5, 2015 09:54 PM
danace99
23
Jun 28, 2015 08:49 AM
JohnnyBxo
16
May 9, 2015 05:53 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
