1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Crank shaft pulley
Old Jul 14, 2007
89hatch408's Avatar
89hatch408 is an unknown quantity at this point
Crank shaft pulley
So im trying to change my timing belt and the crankshaft pulley is giving me some trouble, i know there is a tool available for this very problem but that is unavailable to me right now, so my question is, is there any way to get the pulley bolt loose without using that tool or and impact gun?
Old Jul 14, 2007
89hatch408's Avatar
Re: Crank shaft pulley
sorry its for an 89 honda civic hatchback 1.5l manual transmission
Old Jul 15, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
use a breaker bar with a good length of pipe to fit over the end for super torque
Old Apr 13, 2008
Bud-Jet civic's Avatar
Bud-Jet civic is an unknown quantity at this point
I have had this same problem with later model hondas, I have put a breaker bar on it and cranked the motor over, always has broken the crank bolt free.
Old May 8, 2008
vengeanceasx's Avatar
vengeanceasx is an unknown quantity at this point
Take the dust cover off the tranny and wedge a large screwdriver in a tooth of the flywheel so that it won't turn then get a big ratchet or breaker bar and use it on the pulley. This worked for me about a month ago, although it may take more than one person.
Old Nov 22, 2008
soltero's Avatar
soltero is an unknown quantity at this point
I tried wedging a large screwdriver in the flywheel teeth (after removing the starter) but that proved impossible to hold enough leverage on the teeth while I attempted to break the bolt loose with my foot. I also tried the suggestion of using a breaker bar and cranking the motor (I didn't have access/affordability to an impact wrench), only to discover that it is impossible to do on my 91 Civic LX and actually only results in tightening the bolt further. My crankshaft rotates in counter-clockwise direction, which is the same direction needed to break the seal on the bolt. I wedged a breaker bar against the control arm and it made a loud "THUNK" sound when I turned it over. Then I realized my mistake and came up with the solution below.
The solution which fixed the problem, was to insert a large allen wrench through one of the holes of the crankshaft pulley (rear of the center of the crankshaft) and brace it against the lip of the oil pan. This worked to keep the pulley from rotating while I pushed on the breaker bar (with my foot) to break it loose. This also proved to be a much safer option than using my hands because the car was up on jackstands, and the foot method offered much better leverage (as opposed to using arm strength). Also, since it is an allen wrench, you can ensure that that one of the flat edges is up against the lip of the oil pan so as to prevent damage. This method does however, slightly elongate the holes used with the allen wrench.
To reinstall/retighten the bolt, just insert the large allen wrench through one of the holes forward of the center of the crankshaft and up against the lip of the oil pan and torque it to the specs.
And it does definitely help to have an assistant helping you as opposed to doing everything by yourself.
Hope this helps.
- soltero -
Old Dec 6, 2008
supafil25's Avatar
supafil25 will become famous soon enough
just buy the tool i paid $40 for mine and have used it many times well worth it.
Skunkone
Sep 24, 2015 04:38 PM
pilebuck13
Sep 21, 2015 10:45 PM
Jrosa
Sep 14, 2015 08:24 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
rainman15
Sep 6, 2015 11:10 AM
