96 civic ex problems...please help!
Old Jul 13, 2007
mnea's Avatar
mnea is an unknown quantity at this point
No mods done to this car...But all at once the following problems occurred:
1) Cruise control stopped working
2) Car hesitates upon stepping on gas
3) Brake lights won't turn off
Any idea what may be causing these problems to occur all at the same time and how to fix?
Thanks!
Old Jul 13, 2007
CraigW's Avatar
Re: 96 civic ex problems...please help!
Cruise will not set if the brake lights are somehow on. (it thinks you have brake pedal pushed ) I would test the brake switch as a start. It would be likely source of problem.
#2 ??? May be related to other problems.
Old Jul 13, 2007
mnea's Avatar
Thanks!
How do I locate and check the brake switch?
What other problems may be causing the hesitation?
Old Jul 13, 2007
Alpha 5's Avatar
Your Emergency Brake is stuck. Just a little.
Problem 3: The brake being stuck would cause the light to come on
Problem 1: If light is on then the Cruise will not work
Problem 2: If brake is stuck just a little it would cause you to use more gas to get off the line, or would act like it is hesitant. The Hesitation is caused by the excess of force on the wheels caused by the brake. As you drive the rear brake heats up and then fades. This causes the problem to slightly go away but you also lose the rear brakes.
Old Jul 13, 2007
mnea's Avatar
Hmmm....Didn't realize exterior brake lights came on if emergency brake was used.
Old Jul 13, 2007
Alpha 5's Avatar
I stand corrected.
I was thinking you meant the dash light.
Old Jul 13, 2007
FBHsukka's Avatar
FBHsukka is an unknown quantity at this point
I would agree with CraigW.
I think the brake switch is under the dash.
I'm lost as to where though.
They only cost like, what, ten bucks at auto stores?
Good luck.
Old Jul 13, 2007
CraigW's Avatar
The switch is under the drivers side dash. Move the brake pedal just a bit and you should be able to locate it. (the plunger should be held in when brake not applied and released when pedal moves down) Make sure it is mounted tight (it can be moved in and out threads and nuts) Should be 2 wires coming from the switch.
Old Jul 13, 2007
mnea's Avatar
Thanks...I located it after twisting upside down and like a pretzel LOL
Anyone have any thoughts on what may be causing hesitation upon acceleration?
BTW...had major tune about 6,000 miles ago.
Thanks!!!
Old Sep 22, 2007
mnea's Avatar
Just to follow up...upon having the brake switch replaced all 3 problems were corrected:
1) Cruise control started working
2) Car stopped hesitation upon stepping on gas
3) Brake lights turn off
Thanks everyone!
Old Sep 23, 2007
sql_civic's Avatar
Good call, Craig. Worthy of rep.
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
