1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Honda civic 93 Ex sedan Air condition issue?
Old Jun 27, 2007
jroy3221's Avatar
jroy3221 is an unknown quantity at this point
Why is my air condition not working on level 1 or 2 but when I put it on 3 it blows cold air all crazy? Also why am I losing acceleration when the ac is on?
Old Jun 27, 2007
lordhelmet's Avatar
Re: Honda civic 93 Ex sedan Air condition issue?
Are you losing more acceleration than normal? I ask this because the ac compressor has a huge effect on our four cylinder engines.
Old Jun 27, 2007
foreman400x's Avatar
foreman400x is an unknown quantity at this point
sounds like you need a compressor
Old Jun 27, 2007
lordhelmet's Avatar
First off.... don't rush out and buy a new compressor right off the bat... they aren't cheap. If it blows cold air on three then that most likely means the compressor is still working. Most likely the blower is crapping out or something is up with the wiring or a relay. Or if the air is not as cold as normal on three then it the system could need a recharge AND the blower is going out. Most importantly UTILIZE the search function. Your car has been around for a while so I am sure many people have had that kind of problem before. If you don't have any skill in troubleshooting your car problems then I suggest finding a good mechanic because living w/o AC really bites.
Old Jun 27, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
dude recharging our r 12 systems is a bitch when it comes to cost im looking into a conversion and i suggest you should too
Old Jun 28, 2007
oopsracing19's Avatar
oopsracing19 is an unknown quantity at this point
does it work on 1 and 2 with the ac off? if those settings dont work at all you might be smart to start cheap and try replacing the switch. if that dont work take out your blower and see if there maybe something in it. if there is it could be heavy enough to stop the blower on them settings and when you hit 3 it has enough power to move
Old Jun 28, 2007
jroy3221's Avatar
The air is ice cold when on level 3 and 4, but when it is on 1 or 2 nothing seems to be coming out. Hopefully it is something that just needs to be cleaned or unclogged.
Old Jun 28, 2007
CraigW's Avatar
You may have a defective "blower motor resistor" They consist of coils of wire that lower the voltage to the blower fan at the lower fan speeds. They run hot and as a result the coils can open causing missing speeds. They are normally placed near the blower fan motor in the fans air path (for cooling of the coils) I would look near the blower motor. It will have, 3-4-5? connections made to it. Mounted with a couple of screws. Inspect for open coils and check with an Ohm meter.
Old Jun 29, 2007
mneuls's Avatar
mneuls will become famous soon enoughmneuls will become famous soon enough
you need to disconnect them before you check them, or else you get feedback through the whole system, and your readings go all fugly and weird.
Old Jun 29, 2007
jroy3221's Avatar
Thanks for the fast responses, hopefully this does not cost me alot of money????? That would Any suggestion on the best way to test that blow motor?
Old Jun 29, 2007
CraigW's Avatar
Agreed with unplugging the blower resistor unit before checking, Should be a single plug.
If any coils are broken you should see them easily with visual inspection.
The blower motor is most likely o.k. if it is capable of running at higher speeds.
vtec92
May 4, 2017 03:20 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
jessicakaybby
Apr 20, 2015 12:11 PM
