8th Gen 2006 - 2011.
07 radio removal
Old Jun 14, 2007
blciv07's Avatar
blciv07 is an unknown quantity at this point
07 radio removal
Does anyone know how to remove the radio from a 07 2 door non-nav?
Old Jun 27, 2007
southerndragoncivic's Avatar
southerndragoncivic is an unknown quantity at this point
Re: 07 radio removal
Its kinda hairbrained but if you're determined to do it, you actually have to take apart the entire dash (minus the passenger side). And, theres an order in which the panels come off. However, rather than try and explain it to you, i'll give you a hint and a link to go with it. Find factory/dealer accessory that requires the same disassembly and use its (pdf) instructions. well, believe it or not, i can't find the one i used when i installed my bluetooth kit but i can give you a general order. The first panel to come out is the drivers kick panel. If you have the double kick panel (another one that is black plastic) pop the black one out first. it should come right out. The next one has one or more small screws. after that one is out the upper one (the one that has the tach hood) now, check for any screws. there might be one or two but i think its mostly clips from here on out. once you have that panel out of the way, DONT try to pry the stereo out. there's a small panel under it in that little storage alcove that you have to pop out. This is where it gets to be a pain. Up through that panel (and its not just right inside they're IN THERE) are two bolts that are 1 of three sizes, 8mm, 10mm, or 14mm. You're going to need a ratchet and an extension and be prepared to fumble around a bit. once those two are out the stereo pretty much slides right out, just make sure you disconnect the A/C wires before you pull it out too far. I'm pretty sure thats it
Sky
Old May 3, 2008
User 061820's Avatar
User 061820 is an unknown quantity at this point
http://www.bernardiparts.com/Images/...r_AII33543.pdf
one manual that shows how to remove, it's from an oem provider, its the service manual :P enjoy
yes i am a bump wh*** tonight/morning..sorry guys, just bored and I never really understood the horrors in bumping?
Old May 3, 2008
Alpha 5's Avatar
Here is a complete list of all the wiring for the 07 Civic non SI.
Audio
https://www.civicforums.com/forums/a...3&d=1209819290
Convenience
https://www.civicforums.com/forums/a...4&d=1209819290
Locks and Windows
https://www.civicforums.com/forums/a...5&d=1209819290
Remote start
https://www.civicforums.com/forums/a...6&d=1209819290
Security
https://www.civicforums.com/forums/a...7&d=1209819290
ID:	74233   Click image for larger version
ID:	74234   Click image for larger version
Name:	Locks and windows.jpg
ID:	74235   Click image for larger version
Name:	Remote start.jpg
ID:	74236   Click image for larger version
Dave1984
Jul 22, 2015 06:10 PM
jody501
Jul 10, 2015 11:01 AM
magog45
Jul 9, 2015 06:23 PM
ballmich
Jul 9, 2015 11:59 AM
