rca and ground wires
Old Mar 26, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
i ran my rca and ground wires down the passengers side door. i havent hooked my amp up yet but should i rerun the wires rca and ground wires so they are seperated? i dont really fell like redoing my wiring, but will it make a difference?.. any help would be appreciated. thanks guys
Old Mar 26, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
which rca's did u get? depending on the maker (monster cable's the only way to go), if the shielding is good you shouldn't have a problem,,,worst thing that may happen is you might get some static or interference....
Old Mar 26, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
ran a ground wire down the passenger side? in that case.. take everything you bought, put it back in the box.......
anyhoo.. you prolly meant remote wire.. the remote wire does not draw enough current to create a magnetic field strong enough to distort the sound travelling through the rca cable(s).
Old Mar 26, 2002
nochopstix's Avatar
i meant the power wire not the ground wire.......oops i got rockford rca cables by the way.
Old Mar 26, 2002
mohawkboom's Avatar
Your gonna have a some massive whining noise dude..[IMG]i/expressions/face-icon-small-smile.gif[/IMG].. and Monster cable isn't the only way to go.. Any Shielded RCA's with colt plated terminals are pretty much the same....but definately re-run those wires bro.
Cheers
Mohawk
Old Mar 26, 2002
nochopstix's Avatar
thanks mohawk
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
