deteriorating idle
Ricky Bobby style, IWGF
deteriorating idle
the car will run for a while then the idle will slowly deteriorate and the engine dies its also smoking from the exhaust manifold idk what it could be
i just replaced all the valve seals the exhaust mani and o2 sensors
and i also cleaned the TB and IAC valve
and i also cleaned the TB and IAC valve Thread Starter
Re: deteriorating idle
well i did a compression check and the #1 cyl is at 120 and all cyl after that are lower #2 90 #3 is 80 #4 is 30 but that was before i changed the valve seals and it kind of runs but still having the above problem ^^^ but the compression doesnt bleed off like theres a leak
did you check it after the seals where replaced? most compression gauges will hold the highest level of pressure till you release it. A leakdown test would be even better to find it but i still think its the headgasket
you know your probably right i dont know how to do a leakdown test tho and yes it is one of those compression testers that hold pressure until it is released
how many miles are on your car and has the head ever been pulled before? You should have comression somewhere in the 130 range and they should all be about the same +/- 5PSI.
about 98K and at 88K the engine blew and was swapped with a salvage a2 block and a1 head so i have a block that says d17a2 and a non-vtec head it looked pretty new when i got it and i have a vtec head just needs to be completed assy lube and all
a leakdown test measures the pressure loss and a compression test tests the max cylinder pressure that the cylinder can hold so if there is a leak somewhere you get low compression test results with a leakdown you can tell where the leak is by playing with the crank position
RSKtakR
25
Sep 14, 2015 07:43 PM
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
Bricoleur
Sep 9, 2015 12:23 PM
