Help!! Can't remove U-clip!!
Old Jun 1, 2007
johnnyapple's Avatar
johnnyapple is an unknown quantity at this point
I can't remove the u-clip. what tools or what-not would you recommend.
Old Jun 1, 2007
Alpha 5's Avatar
Re: Help!! Can't remove U-clip!!
What are you talking about? A pic a discription some thing. Come on toss us a freakin bone here.
Old Jun 1, 2007
the u-clip is on the e. brake lever on one of the brake shoes.
Old Jun 1, 2007
Alpha 5's Avatar
How can it be on the lever and on the shoe? Hmmm
Old Jun 1, 2007
its what connects them
Old Jun 1, 2007
well on my car at least
Old Jun 1, 2007
Alpha 5's Avatar
Find one of gearbox's posts, they are every where, and send him a pm. That should do the trick.
Old Jun 1, 2007
this is what it looks like
Old Jun 1, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
open it up a bit with pliers, then squeeze them out... with pliars
Old Jun 1, 2007
by squeeze do you mean twist sideways?
Old Jun 1, 2007
rice4lyfe's Avatar
get some needle nose pliars and open them up (sticking them perpendicular to the opening)
then kinda have one edge of the pliars to the anchor and the other edge of the pliars to the opening edge of the pin
Old Jun 1, 2007
MidnightCivic's Avatar
hire a PROFESSIONAL
Old Jun 1, 2007
skipbarber's Avatar
i use a small flat head screw driver. slide it in and then twist the screwdriver, this causes the clip to open up, then using a pair of pliers, use the pin as a leverage point for one jaw of the pliers and use the other end to slide the clip off of the pin completely. give it a few tries and youll get it out. just be sure to replace the clip with a new one when you go to put it together.
Old Jun 2, 2007
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
if hes gunna have to replace it might as well rip that thing right off That would totally do it but i think he just wants to reuse it..i forgot the name of the tool i used in transmissions class to take the clips out of the axles andcrap someone has to know it was something like a backwards needle plier something like that
Wait what are u trying to do in the 1st place anyway?
Old Jun 6, 2007
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
That clip is a cast-iron 90 MPH bull dyke bitch.
It took me an hour to remove the first one... get a big set of end nippers or a dremel and rip the MFer off, a new one is like a buck.
Damn HeadGasket
Aug 23, 2015 05:27 PM
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
