Burning oil bad
Old May 12, 2007
Mr.honda's Avatar
Mr.honda is an unknown quantity at this point
Burning oil bad
I installed a tsi kit on my car about a month ago and now the thing burns oil and smokes like none other. Anybody have this prob or any ideas on what is wrong? Any help would be great. Thanks
Old May 12, 2007
Re: Burning oil bad
what does the turbo or the car? must have a leak somewhere, it shouldnt be burning oil just due to being turbo
Old May 12, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Re: Burning oil bad
Either faulty turbocharger or damaged pistons/rings.
Check compression, it it's ok, then it turbo itself.
Hope it is turbo, becuase you should have one year warranty still.
Old May 12, 2007
Mr.honda's Avatar
Re: Burning oil bad
I did not install the oil pressure reducer. Could that be the problem? I read about it in the instuctions after we were pretty much done with the install. The compression is good and the plugs are the brown chocolat color they are suppose to be. I thought that I forgot the reducer maybe it has to high of oil pressure and it blew out the seals in the turbo.
Old May 12, 2007
tfnaaf's Avatar
BLDNPSI Mod
Re: Burning oil bad
Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, Ding, I think we have a winner!
Old May 12, 2007
skipbarber's Avatar
Re: Burning oil bad
i did the same thing, i ran my t3 without a restrictor for a year, and when i finally decided to install it, it was too late. i blew the seals on it and smokes a bit but it's not making it into my intake, so i dont really care. it's an older turbo and i was planning on replacing it this year anyways.
Old May 12, 2007
Mr.honda's Avatar
Re: Burning oil bad
What do i use for a restrictor? I never found it when I whent to look for it after I found out.
Old May 12, 2007
skipbarber's Avatar
Re: Burning oil bad
http://cgi.ebay.com/ebaymotors/Turbo...spagenameZWD1V
thats what i used, im using the golden eagle oil filter sandwich adapter to feed my turbo. i have that in between the sandwich and the 1/8" npt to -3an line adapter. if you dont have any NPT fittings in your line set, you might be able to find something similar in AN threads.
Old May 12, 2007
Mr.honda's Avatar
Re: Burning oil bad
Thanks for the help! That's what I will get
Old May 12, 2007
skipbarber's Avatar
Re: Burning oil bad
that particular one works really well, just be sure to teflon tape it.
Old May 13, 2007
Michalo187's Avatar
Abortion Survivor
Re: Burning oil bad
hmm i have never heard of someone using it will i need this if i run gt30?
Old May 13, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Re: Burning oil bad
Precision sent me an AN fitting with my GT30 that has the proper sized orrifice.
Old May 13, 2007
Michalo187's Avatar
Abortion Survivor
Re: Burning oil bad
^^^I am getting garrett, do you know if i will need this?
Old May 14, 2007
02fpcivic's Avatar
Re: Burning oil bad
yes, ball bearing turbos are sensitive from what I was lead to believe
Old May 14, 2007
Michalo187's Avatar
Abortion Survivor
Re: Burning oil bad
Yeah i willl probably get that, its 12 bucks what the hell.
Old May 14, 2007
andyman97's Avatar
Turbo Guru
Re: Burning oil bad
Keep in mind this isn't always necessary, it depends on the size of your feed line. I'm running a -3 line and have no restrictor, haven't since I've had the turbo....
Old May 14, 2007
Michalo187's Avatar
Abortion Survivor
Re: Burning oil bad
^^^^^ thanks for that clarification mang your knowledge is always appreciated
Runner88
Mar 2, 2023 04:54 PM
MyCivic
Electrical
Oct 28, 2021 11:06 PM
RIPSAW
Nov 6, 2015 04:36 AM
zaboomafoozarg
May 30, 2015 09:21 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
